1156 bulb for turn signal
ok, i want to change my 1157 front turn signal bulb to an 1156. what i want to know is, if i change it to an 1156, will the bulb turn on when i tunr on the parking lights? or will it turn on ONLY when i put the turn signal on? i would like for only my fog lights and low beam to be on when i turn them on.
So basically you don't want the front ambers to be in for parking lights.... only for turn signals. Maybe get a 1157 and then cover one of the contacts. If not cut that wire
Originally Posted by edgalang
:banghead:
NSXNEXT already answered your question.
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
Purchased: April 28, 2001
Originally Posted by AcuraTLS03
i understand that, but the rear turn signal only turns on when you activcate the turning signal and u said the rear turn signal is a modified 1156 bulb. so i was asking if that modified 1156 bulb will work for the front turn signal.
The only "modification" you do is cut/file a tab to make the bulb fit in the housing. Regardless if it's modified or not, by putting a 1156 in the front turn signal, it'll do what NSXNEXT says it'll do.
I suggest you try Bxscig's suggestion.
09-17-2015 09:01 PM
Greengecko
09-16-2015 08:19 PM
