1/4 Mile Track
1/4 Mile Track
Hey,
I am thinking about to go to the track tommorow and test my car after seafoaming it. the last time i did 1/4 mile track was about 3 months ago, My question is can i damage my tranny if i just do about 2 races to test D5 and SS? because i have been reading the tranny failure threads and now i am getting scared to do anything at all..
downshifting into 3rd and 2nd is whats hard on the trans
Use the brakes at the end of the race~
6MT Someday..
TL-P? ^^^ mid-high 15's
Ive heard that gate shifting is the way to go-shifting just before the rev limiter- when drag racing our cars. (move the shifter up through the gate on the right, starting with 1.)
If youre not too confident doing so, just leave it in d5. I wouldnt be out there banging the hell out of the car, our transmissions arent known for durability and reliability.
6MT Someday..
nice!
VMAN-gate shift if youre gonna go...Make a couple passes, just dont go crazy. DISCLAIMER:Im not responsible for any transmission issues that may ensue!
Gate is on the right..start all the way at the bottom, move the shifter through each gear just before the rev limiter..good luck
well took my car after seamfoaming it. My car is a 2000 stock tl-p and before seafoam i ran 16.9 to 17.1 Now i ran 16.5 in D5 is that good? All stock no headers or anything
And the 1/4 mile isnt going to kill your trans. City driving is far harder on it.
I thought i did great there was a si doing 16.3 stock. my tl was never raced now i am the second owner and i step on the pedal. Well i seafoamed my car what else can i do that involves cleaning?
I am located in washington state, and the track is just a city track, when i got 16.5 my tires did not spin they are some touring tires from previous owners and have good tread so i keep them until they go bad. Does that gain time if i dont spin
I dont believe that, an evo did at the track 14.1 stock. An evo will beat a tl-p.
fsttyms1 are you all stock??
the 14.9 i did was with the auto 7 years ago. I told you the only mods i had was the removal of resonators, comptech axle back exhaust and Good tires. Like rajca said, there is more to the 1/4 than bolting on parts and giving it gas. YOU need to learn how to drive, you need to gate shift, brake torque, shift at the exact time you need to. Inflating your tires to the correct PSI (not what is recommended on the door) Every little thing helps. If you can remove some of your interior you can benefit as well.
2003 Accord Coupe V6
hey vman, what track did you run at? what was your elevation? This makes the whole difference in what you run. If you are around sea level you should be at least in the high 15's to mid 15's at best. If you are here in tucson where I live at 3075ft elev. you would be in the mid 16's - high 16's.
2003 TL-p
example:
going from a cruise at 50 mph to wot (going from 5th to 2nd) will cause more wear than going wot from a stand still?
stop and go traffic must be hard on the clutch packs, and having it shift at lower rpms might actually cause more wear?
That evo driver needs to learn to drive as well
2003 TL-p
i remember a while back i did a ruff estimate quarter mile on a back road and got somewhere around 90 mph completely stock, i didnt time it.
The Dumb One
i have a 99 AUTO 4 speed...
i ran 15.45
you ARE being compared to a stock auto...
your car is extremely slow compared to a clean running TL.
PS the SI's are not fast at all stock.
16.3 would get smashed by my stock TL all day long...
i ran 15.45
really? so up-shifts do not cause anywhere nearly as much wear as down-shifts? i should not worry as much about causing excess wear on a spirited take off, its down-shifts that's the problem and something to avoid?
example:
example:
I got to about 85 mph but i didnt do pedal to medal on start. Isn't it dangerous for the engine to take out the intake resonator??
2003 TL-p
2003 TL-p
