09 tl intake manifold and ported runners parts?
Chapter Leader (Southeast Region)
I have all the parts, Now I just need to make sure I got all the hardware. I got new valve cover gaskets, intake manifold to runner gasket, gaskets for the the lower intake manifold to heads, throttle body gaskets, and a couple of bolts civicdrvr said I needed. Can anybody else think of anything else I need?
I will try, I'm going to be tryig to pay attention so I don't drop a bolt down into the engine. I'm sure ican take a few pictures though and write something up.
MechEng
Please please please do a DIY for all of this. My engine desperately needs more air. Also how much did he charge to port the Type S runners (not including the cost of the actual runners)?
He already had the runners so I didn't have to get them. I'll send you a pm I'm sure he doesn't want me posting prices on here in case he needs to charge more next time. I'll defidently try to make a DIY for this just waiting for a few more parts to come in
03tLsNBP (10-24-2012)
Stephen00TL (10-24-2012)
takin care of Business in
Received 4,732 Likes
Stephen, the intake runners are the same for all model years in the 3G....when you said a Type S, am assuming you are talking about the 3G Type S....and no matter how big you bore the manifold and runners it wont matter if you dont have a bigger TB....look into the SHAWD Manifold and SHAWD TB
swoosh (10-24-2012)
^^^ ohhh shit....totally forgot about that....
just make sure you use the latest MAF sensor...a lot of people on the 3G side are having idle issues from using the older MAF sensor...again just putting this out there...am not even sure if you guys have the MAF sensor....
I haven't heard of that problem with our generation yet but will keep that in mind. The only idle issues I've heard of from our generation is from gasket leaks.
17160-RK2-A00 - Intake manifold -218.76 Oemacuraparts.com
17140-RK1-A01 - Intake manifold cover -165.70 Oemacuraparts.com
P2R throttle body adapter- 09 tl intake manifold to 2nd gen type s throttle body- 69.99 - throwdownperformance.com
( http://throwdownperformance.com/inde...oducts_id=1579 )
I got ported Type Lower manifold (you don't have to get that to make this work)
I got a Type s throttle body so it flows better.
16176-RK2-A00 - 09 tl throttle body gasket- .49 - oemacuraparts.com
16176-PGE-A01 - 03 tl type s Throttle body gasket-2.5- oemacuraparts.com
17105-P8E-A01 - intake manifold to runner gasket- 13.45 -oemacuraparts.com
17055-P8E-A01 & 17065-P8E-A01- lower runner/ manifold gasket- 2X 10.86- oemacuraparts.com
90104-RCJ-A00- Two bolts to you need need for manifold swap- 2.01- oemacuraparts.com
I think that's everything I needed
The following 5 users liked this post by Stephen00TL:
03tLsNBP (10-25-2012),
AznWay (05-17-2013),
kak0019 (02-05-2013),
Naija'sTL (04-16-2013),
P-TownTL35 (02-04-2013)
This is what I was talking about and the reason why I got type s runners. Look at the size difference between the two. Photo taken from richardparker these are not mine.
For referance.
The runner in the rear are from a clp
The runner in the front is a type s
For referance.
dude thats night and day !!!
Exactly and it's not really mentioned on here. That along with the larger intake manifold is probably a big part of the power difference between the type s and base.
cycdaniel
12-17-2019 10:58 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
