04 TL steering wheel in an 03 TL ??
just curious if anyone knew whether or not it was possible to put a newer TL steering wheel into my 03 TL-S..any helpful information would be greatly appreciated..
well its nice to know its possible..almost seems like too much work but my steering wheel is getting worn down and if i got to put a new one in there might as well get a newer one
that looks better
that looks better
The bolt pattern would have to match up< and the Air Bag. Most steering wheels dont come with the airbag. You cant remove just the bag and place it in any old wheel. Also the 99-01 have Single stage airbags. The 02+ have Dual stage. You have to trick the Airbag ECU with some resistors. That and the color. While they look the same once in they may not.
VERY easy to replace the steering wheel -- https://acurazine.com/forums/1g-cl-diy-faq-74/1st-gen-cl-steering-wheel-diy-w-pics-486041/
The wiring would be hard if you know what you're doing.. a stereo install shop or tuner shop would probably be your best bet if you were going to try and get it done. A body shop would probably install the wheel, but not do all the custom wiring.
rockyboy
Aug 4, 2024 10:35 AM
EvilVirus
Dec 10, 2015 07:38 PM
