'04 Rear Sway on 2nd Gen?
I'm trying to sell my stock sways over at v6performance.net, and some dude said that the '04 TL rear sway fits on the 98-02 Accord... If I'm not mistaken, 2nd gen sways are the same as the 98-02 Accord, and if the '04 rear sway doesn't fit on our 2nd gen, they shouldn't on the Accord either, right? Someone confirm this, thanks.
Ok I've done some reading on v6performance.net...
Apparently the 20mm '04 TL rear sway does fit on 6th Accords (98-02)..You do need new brackets and bushings though. I'm not sure about the front sway, but I guess that doesn't really matter since the rear one is what's important and most easily purchased.
Theoretically speaking, then the '04 TL rear sway should fit on our 2nd gen TLs? If that's so, it'd be an great cheap upgrade for TL-P owners.
Originally Posted by fsttyms1
why not just get one thats for our cars? or you could get the type s bar thats bigger,
TL-P 18mm rear
TL-S 19mm rear
2004 TL 20mm rear
I bought used eibach sways (23mm rear), and they set me back $220 shipped. A 2004 rear sway will cost you about $50. True, the eibachs are thicker/better, but they're prolly not worth the extra $150+
Initial D
My understanding is:
TL-P 18mm rear
TL-S 19mm rear
2004 TL 20mm rear
TL-P 18mm rear
TL-S 19mm rear
2004 TL 20mm rear
Initial D
Try Dean Baty, he has a shop to get discount from CT and helped many members. I got rear sway from him. email: deansbluesi@yahoo.com, 407-772-0070
Initial D
id stick to the one thats designed for our car and bigger.
DiamondJoeQuimby
09-10-2015 11:40 AM
