03 TLS Fog Light Bulb
Kollage is funn!
1 Post
Hey everyone. I was washing and admiring my car this morning, when I realized that i didn't like the way the foglights and xenon headlights look together. Believe it or not, I only found ONE bulb especially for 03 TLs on Ebay that were "xenon." And i missed the auctioned. I really don't care if it's real or not, i'm not gonna spend a grand on fog light bulbs. Bottom line, i want to know if anyone knows where i could buy "blue" light bulbs. Either online or through a auto parts store. I'd really appreciate it. -Shawn
Do you want it to emit a "blue" light ? Or are you looking for a better match to the headlights. I wanted a better match to the headlights. A cheap way to go is get a pair of 9006 bulbs from midnightmoose.com. Safe way is to get 55w bulbs. I acutually put in the 85W bulbs because a few people here tried it. From what I recall reading, they didn't melt the harness or foglight case. I've had them in for a week now and they don't feel any warmer than the stock ones when I put my hand to the lense. They are a lot brighter and almost match the headlights.
For the 85W bulbs or higher than 55W... You could also change the wiring a little with a wiring harness that draws the power from the battery... protecting the stock harness and wiring.
You might want to try a different color so matching isnt a problem. I did yellow.
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
btw: nice write up on your fog light mod
Basically, you hook the 9006 bulbs to the battery and throw a fuse and relay inbetween the battery and the bulb. The relay hooks up to your OEM 9006 harness and only needs VERY VERY little current to operate. Once the relay is turned on my the 9006 OEM harness in other words you turn your fogs on.... the relay will close the circuit inbetween the the battery and bulbs.
Kollage is funn!
1 Post
hey thanks for your reply. Owning an acura, you do notice that the blueness of the headlights are pretty blue....did the 85W match it pretty close? And also one more thing, i want a solution with very little modding of the harness, wiring, and car. So bottom line, you're saying that the 85W lights would be a close match, and strong as the headlights right? thanks a lot. -Shawn
Kollage is funn!
1 Post
Okay, i found the 9006 lights from midnightmoose.com, would that thing fit in my assembly? And this wouldn't require those ballast boxes right? 'preciate it. -shawn
Kollage is funn!
1 Post
For the last time, (sorry) a 9006 will replace a stock fog light config? Just remove the stock white bulb, and insert the 9006 bulb. If that's correct you wouldn't know about the whole 85W melting issue would you? I'd like it to be strong like an 85W....lemme know. Much thanks. -Shawn
Ok, the regular bulb (stock) is a 9006 Bulb, so if you buy another 9006 bulb you are good to go. Choose what you will between 55Ws and 85Ws. Some people recommend against 85Ws and some say they have no problems.
The high beams are 9005 bulbs.
Ok, thx for the tip Bxscig !
Shawn, for what it's worth, I remember reading that someone did a comparison from of the eaglite 55w bulbs vs. the 85w bulbs and there wasn't a big difference in the brightness. Of course I read that after I bought the 85w bulbs.
Kollage is funn!
1 Post
Okay, guys, quick update. I drove for about an hour today with my fogs on....i felt them to see how hot they were...it was too hot to the touch on both sides of my hand. From your own experience, are the fog lights as blue as the headlights? BTW, i'm thinking of getting the 55W. Any thoughts/advice about installation? Thanks a lot. -Shawn
It is definitely too hot to touch. I learned the hard way too. I just went with purple and yellow because matching HIDs with halogen bulbs are hard. You will need a 10mm + ratchet + about a 6" extension to get to the bolt holding it.
Kollage is funn!
1 Post
Okay....a few more things. Those 55W 9006 bulbs....do you know how many K they are? (6000, 7000k)....Same for the 9005 high beam lights. And do you know how many K the STOCK low beam true HIDs are? Thanks. -Shawn
Kollage is funn!
1 Post
Do you personally think that if i get the 9006 fogs it'll look stupid or faggy with the headlights? I'm trying to decide.....Yellow wouldn't be bad, but i'm not really a fan. Thanks. -Shawn
I think that anything besides stock will look better lol The stock ones look bad to me but they last. The aftermarket ones, be warned, do burn out more often.... like in a month or 6 months... depending on how often you use them.
Just get Eaglites from www.midnightmoose.com Many people have ordered through them and at the 15.49 price ... you can afford to get a couple.
Purchased: April 28, 2001
Originally Posted by shawn744
...I realized that i didn't like the way the foglights and xenon headlights look together...I only found ONE bulb especially for 03 TLs on Ebay that were "xenon."...i'm not gonna spend a grand on fog light bulbs...
BTW...here are some pics for you to compare.
Max GOLD 55W
![](http://www.acurainspired.com/gallery/data/58a2fc6ed39fd083f55d4182bf88826d/342_p15479.jpg)
![](http://www.acurainspired.com/gallery/data/58a2fc6ed39fd083f55d4182bf88826d/342_p15483.jpg)
Eaglite Xenon 80W
![](http://www.acurainspired.com/gallery/data/58a2fc6ed39fd083f55d4182bf88826d/341_p15461.jpg)
![](http://www.acurainspired.com/gallery/data/58a2fc6ed39fd083f55d4182bf88826d/341_p15470.jpg)
80W Hyperwhite vs 55W GOLD
![](http://www.acurainspired.com/gallery/data/58a2fc6ed39fd083f55d4182bf88826d/342_p15474.jpg)
![](http://www.acurainspired.com/gallery/data/58a2fc6ed39fd083f55d4182bf88826d/342_p15475.jpg)
Originally Posted by Bxscig
Like edgalang said I was done wasting money on those bulbs. They burn out so much and so fast.
Especially with your true DTR lights...those bulbs shouldn't even be considered.
Kollage is funn!
1 Post
Hey DJ5- about how long have those PIAA Xtremes lasted? I should've checked this thread i just bought PIAA extremes 47000k. i spent like $90.....it's gotta have some kind of warranty....SHIT......(there's a 20% restocking fee if i return them....)....i dunno what i should do. Any suggestions appreciated
-shawn
-shawn
It's too late to beat yourself up now. Just use them for the mean time and when they burn out, don't buy another set.
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
