03 acura tl low beam headlights and radio
Old 03-06-2014 | 07:12 AM
alexxismarriee's Avatar
i've been going insane trying to figure out whats wrong with my car. for starters, my low beams do not come on every time i try to turn them on. one bulb went out so i got them both replaced. right bulb didn't work, left bulb did. now it flipped flopped. right side works, left side doesn't. anyone else have this problem and figured out what was going on?
also, when battery was disconnected from headlights getting changed, my radio completely stopped working and doesn't work when i enter the code.. how do i fix this?
Old 03-06-2014 | 07:39 AM
cincinattlguy19's Avatar
06 NBP 6MT TL
First, check all fuses. Right/Left headlight and radio. For the headlights, make sure all connections are secure and making good contact. What kind of bulbs did you have them replaced with?
I know some guys have issues with the radio taking the code. I have never had an issue, but those guys go under large structures (like under parking garages) and the radio will take the code.
Old 03-06-2014 | 07:42 AM
fsttyms1's Avatar
Check the wiring for the headlights, make sure nothing is corroded.
For the radio, disconnect the antenna from the back of it and then enter the code.
handsom-hustla
11-13-2015 05:04 PM
theinsvnity
09-10-2015 10:22 PM
iRaw
ILX
09-05-2015 12:10 AM
voigt
09-02-2015 10:44 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: 03 acura tl low beam headlights and radio
