02 TL w/ VSA modulator issues....
Old 11-01-2010, 06:13 PM
RCooper's Avatar
Hello everyone I recently took my 02 TLS into the dealership because I noticed the VSA light on. Well was I in for a surprise I was told that my VSA modulator had went bad and that it needed to be replaced and that the part was $1961 installed new and $868 installed new. Anyone have any exp w\ this any info would be greatly appreciated. Thanks.
Old 11-01-2010, 06:37 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
any back story to this??- work done on brakes- driven thru deep puddles--
Old 11-01-2010, 07:25 PM
RCooper's Avatar
I havent driven through any puddles. I had my brakes replaced at the dealership last year. The only work I had done recently was suspension work. The VSA light first started out by turning on then it would sometimes turn off, then it just started staying on so I took it to the dealership. According to the write up they gave me they did the following: Inspected VSA motor for DTC 53 (?), Motor did not run. Found bad ground repaired bad ground but still did not run. Hot wired motor. Did not run. Diagnosed bad modulator Assy Also had bad side mount listed....
Old 11-01-2010, 07:42 PM
RCooper's Avatar
the lights that are on are the VSA, ABS and the triangle w/ the !
Old 11-01-2010, 08:44 PM
RCooper's Avatar
I also recently had the front engine mount replaced
Old 11-01-2010, 09:02 PM
CL-S 6MT Navigation
Type JDM's Avatar
The VSA modulator is the piece that looks like a throttle body ? If so I have 2 of them. I removed them from when I converted my cars to manual transmissions.
Jamus22
06-11-2023 10:08 AM
copmagnet82
4G TL Problems & Fixes
06-29-2016 08:09 AM
MilanoRedDashR
10-08-2015 10:30 AM
SUPRMN84
10-07-2015 09:46 PM
polish_pat
09-30-2015 12:22 PM
Quick Reply: 02 TL w/ VSA modulator issues....
