02 TL-S seats in 2000 TL-P
I just swapped 02 tl-s seats(front and rear) into my 2000 tl ran into a couple of problems...
1) the tl-s main-power harness/plug under the driver seat is different(figured because of the memory feature on 02-03 models) compared to the 2000 tl-p one. can anyone get me the 2 diagrams for 02 tl-s/2000 tl-p.. I'm gonna re-pin and switch the wires needed to power the seats.
also the rear top tl-s seat don't sit as flush as the tl-p ones. I can get it to rear top seat to sit low enough so I can install the 2 10pm bolts on each side..
I'm sure someone did this seat swap before and any help would be aprreciated. thanks in advance
I know with a good search there have been a few members that swapped them and the wiring diagrams are posted somewhere.
As for the 2nd question, i dont understand?
MechEng
check out my thread. there are a couple wiring diagrams in it. i had the same issue when i was putting 02 TL-S seats into my 03 TL-S.
https://acurazine.com/forums/2g-tl-1999-2003-98/02-tl-s-driver-seat-03-tl-s-806356/
thanks!! Im gonna try it today..
sorry about the mix up with the rear seats..
there's alittle gap between the rear top cushion and rear bottom. I can't get the rear top cushion to come down flush or low enough so I can bolt up the 2 10mm bolts on each side. I was kinda rushing it so I'm gonna double check everything today... thanks again guys
Im doing the same swap on my tl-p, im using the diagram posted on 03tLsNBP thread... i'll be doing the actual conversion tomorrow, any luck on yours? does everything work the same?
i keep pondering the idea of having the memory feature in my 00 tl-p... if i find the module and driver door panel i might try it.
i got the seats in.. i havent figured out the whole wiring diagram so my driver seat doesnt have any power yet. lmk how your wiring goes, hopefully you can help me with my wires. im just looking to power the seats dont need the whole memory function of the seat. if you could post any helpful info i would appreciate it thanks in advance
I have my manuals back so ill see if i can get the wiring posted up later today.
The Dumb One
i swapped out my entire interior a couple years back..
i just swapped the new cushions on the old seat frames... couldnt get the wiring correct at first and just did this. just takes a little elbow grease
you get to use your original wiring harness/motors...
it turned out fine.
it turned out fine.
MechEng
oh shit. i didnt even think of doing that. how long did that take you? any tips to make the process easier?
i still havent swapped in my black drivers seat yet because the wiring harness is different. its been sitting in my garage for 2 months now lol.
The Dumb One
everything just unclips and unbolts...
just simply take apart both seats.. the top cushion slides over the framing.. the bottom cushion bolts down on top of the frame.
seat motors and heaters fired right up after install..
wish i had just done that from the beginning.
The Dumb One
i got all of mine for under $500 shipped from a private seller on ebay. everything was included except the carpet.
front and rear seats, panels, dash, console, pillers, seat belts, mats.
but i was lucky.
but i was lucky.
MechEng
just took my black seat apart today. took a bit of elbow grease as you said, but i got it done. just gotta take apart my tan seat tomorrow morning and swap the cushions.
im lucky since im swapping from one Type S to another Type S, i dont think i need to swap the motors or control unit or anything.
MrHeeltoe
20
02-23-2023 01:54 PM
MetalGearTypeS
08-29-2016 08:28 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
