02 tails
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
hey
i was look thru ebay for 02 tails and see they have some for $200. are these cheap knock offs or are they reliable? there were 2 listing one from procarparts.com and the other one is some other site.
thanks
thanks
It's just tail lights. Even if they leak and fog up you'd not notice it. But it can't be too crappy, otherwise you'll have your spare tire floating in a water pond
Tatewaki
Tatewaki
heres the links:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1874753421
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1874634524
i donno if i should buy them off ebay or not. whats ur opinions?
They are 100% compatible! I bought the same JDM's ( Matrix) for my 99tl about a month ago off of Ebay, absolutely NO PROBLEMS. They even come with an amber bulb for the turn signals.....Just pop off your factory tails and pop in the new JDM's.......
same here, i also got it from matrix racing, best part is that i dont even need new wire harness..... its a wonder how much better your car can look after these lights are in.....
ditto...i got mine from matrix and they're good so far...i left my clear bulbs in though. the only difference is that the rubber on outside edge toward the side of the car is not as thick as the OEM ones. there may be a little space there for moisture to get in but it rained really hard in philly this week and there was no moisture build up in the housing so its cool so far.
-Matt
-Matt
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
