02-03 TL Projector Retrofit Build
Here is the progress on my 02 TL-S projector headlight retrofit. Ive done a bunch of retrofits in the past, but these i decided to take my time with over the past couple of months.
I went with brand new TYC Headlights, mint used Nissan Maxima HID Projectors, BMW E30 Projector Lenses and Black Passive Demon Eyes. I tried to keep it clean and OEM+ as i could. The corner reflectors i sent out to maine coast customs for Carbon Fiber Hydrodip. And for the Projector Shrouds i went with Aftermarket G37-R. I feel it came out very clean. Let me know what you think.
New TYC Headlights $195
Maxima HID Projectors $45
E30 Clear Lenses $35
G37-R Shrouds $30
Carbon Hydrodipped Reflectors $50
Morimoto D2H HID Bulbs $25
Hyluxtek 45W Ballasts $90
Amp Extensions $7.50
Silicone Dust Cap $9
D2S Housing Grommets $10
Silica Packs/Vents $10
Misc parts $15
Total Parts - $521.50
Oem Maxima Projectors
Oem maxima lens vs the oem e30 clear lens
Black passive demon finished
Both reflector buckets cut
Driver side Projector epoxied
Both projectors mounted and epoxied into place
Fitting the new projector modified reflectors in the back housings
Shroud cut and fitted
Cut the shroud more to sit further back
Amber reflectors hydrodipped carbon fiber
Mounting the new reflectors and making sure they are secured
Finished one side
Both driver and passenger carbon reflectors mounted and secured
Both shrouds mounted and epoxied
Lenses secured with new retrorubber
Amp extensions with new grommets
Bulbs mounted
Extensions mounted
Dust caps cut, pvc cut and epoxied to the dust caps
Rubber caps secured to the new modifed back caps
Finished
Headlights mounted
First fire up
Alignment is alittle off
Alignment fixed for now
Finished Product!
G37-R Shrouds $30
Misc parts $15
Finished one side
Bulbs mounted
Extensions mounted
Finished
Headlights mounted
First fire up
Finished Product!
The following 3 users liked this post by UA5_6MT:
Nice and clean!
Midnight Mystery (07-17-2020)
Why D2H instead of D2S bulbs?
Arkady (07-17-2020)
D2h worked better with my hyluxtek 45w ballasts, cleaner install than the big igniter on the back. Id go with d2s if i had the 200+ for the bulbs that i want, but the morimoto d2h are $45, its cheaper just to replace them every 2 years.
These were mini d2s 5.0s, wasnt really liking the blackhousings at the time. another member ended up taking them off my hands
Midnight Mystery (07-18-2020)
Wow, that looks fantastic!
Are you going to keep the high beam bulbs as they are then? The projectors I used had that little electromagnetic flapper to remove the cutoff plate for a "high beam", so I disconnected the wires to my OEM high beams but kept the bulb in.
Midnight Mystery (07-22-2020)
97BlackAckCL
08-04-2008 01:48 AM
