==A couple issues need to ask....
Old Oct 29, 2007 | 09:29 AM
Midwest's Avatar
1/ I changed the sparkplugs, the old plugs (90k miles) still look good and the gap are 0.035mm for 5 of them and one of them has 0.04mm. why is it? the book suggest 0.04 mm and why manufacturer put in 0.035 mm? (I own the car since 50k miles)
2/ The new xeon light bulbs bought on ebay item 270176436108
Phillips D2R 4300k Made in Germany (original specs) doesn't bright as the original. everyone else see it more bright?
Old Oct 29, 2007 | 10:03 PM
Rsoetidjo's Avatar
Rich
1/ Stay with factory spec 0.04 mm.
0.04mm and 0.035mm could be when they put it on the car, they never check them.
some of the spark plug have different gap, even the brand new one out off the box.
2/ They should looks identical. (It's only in your head, men)
Old Oct 30, 2007 | 08:39 AM
01tl4tl's Avatar
New bulbs take about 100 hours of use to get fully "burned in", similar to bedding brake pads.
It takes a while, then the color and brightness should stabilize
Just use them in the daytime to add some hours
There is a reason for cheap bulbs and expensive good bulbs
Old Oct 30, 2007 | 08:54 AM
Midwest's Avatar
that make sense. thks
cycdaniel
Dec 17, 2019 10:58 AM
snorf
Nov 4, 2019 06:44 AM
01CLOwner
Oct 9, 2015 01:07 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
NSolace
Sep 3, 2015 08:14 PM
