wheel off set
Originally Posted by Roy Cya
It should be a little narrower: from 38mm to 45mm. The ones some of have bought in the 8.5" width are 38mm offset.
Good luck,
Good luck,
Thanks for the answer.
I checked out the wheel 5x120-18x8-40 mm off set on one of the website and this is what they told me:
The offset on the Privat wheel is not high enough to fit your vehicle.
Regrettably we do not have any wheels that will fit your vehicle.
The data on our website is incorrect and we will be fixing it shortly.
Thank you
Buy Wheels Today
I have read about this problem with the RL. The 4 piston brake calipers require a lot of clearance and even the new RonJon Legend wheels had to be slightly redesigned, the offset going from 45 mm to 41 mm. He calls them retardedly huge brake calipers
https://acurazine.com/forums/showthr...4&page=2&pp=25
The Acura A-Spec wheels which maintain the 55 mm offset must be some piece of design work. I guess that also says the car is so heavy that it really needs these big brakes. I think the brakes are very good, by the way.
+38 fits perfectly on the car, easily clearing the calipers. Many shops selling wheels think the car requires a +45, but they are wrong. The 5Zigen rep had to set Discount straight when I got my rims....
Jay,
I told them that some people installed rims +38mm to +41mm without any problem and this is what they sent me in the email.
Here is the copy from the email.
Seems like they would stick out from the fenders with that width and offset.
So they will certainly bolt on but not fit properly.
Thank you
Buy Wheels Today
Thank you
Buy Wheels Today
Originally Posted by AsianTL
Jay,
Thank you
Buy Wheels Today
Thank you
Buy Wheels Today
I did forget to mention that my rims are 19".
Jay,
Thanks for all your help.
I know you have 19" rims.
They meant 8.5 width
Let us know what you finally end up with!
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
braveheart
Sep 7, 2015 08:12 AM
