Sway bar links vs. Sway bar bushings
2002 RL
OK, my RL has been making some knocking & creaking noises going over bumps, etc. I've been told by 2 separate mechanics that new sway bar end links will take care of the problem.
I've been doing some searching on these forums and have found some who have just replaced the bushings, not the entire link.
Is there anyone who has just replaced the bushing who can comment? The bushing are considerably less than the end links. I don't have a problem replacing all of the sway bar end links if that's the only solution but if all I need are bushings, then why not just do the bushings. None of the sway bar links are broken so it's just the bushings that seem to be worn.
Any comments would be much appreciated.
So, you know the "link" is the rod attachment and the "bushing" is the, yeah you do. If the rod(s) aren't broken, this is darn tootin' a bushing replacement and an easy one. It's so easy that you might consider swapping in an 09/'10 rear swaybar with the new bushings that fit it (same outside, bigger bore hole for larger bar).
It's not enough of a performance upgrade that the expense to install the front bar met my criteria for dollars to effect/need, but it's an excellent upgrade for the money, out back.
2002 RL
Well, I ordered the sway bar end links, all 4. I might pick up some bushings too. Spent $120 on the endlinks but if I can replace just the bushings without too much trouble, I'll just return the end links and save a bit of cash.
engine removal not required the subframe and exhaust have to be dropped down if your replacing the sway bar. but sway bars rarely go its usualy the bushings and the links at the end
Hey,
1) Anyone who replaced rear sway bar bushings on 2010 RL(or similar), did the RR and LR sides matter? I found online OEM bushing but title only mentions "rear bush" which leads me to believe it is for both sides. Link to the part: https://www.acurapartsforless.com/oe...er-52306sjaa11
Interesting thing though, I have an image of my right rear side and it shows RR and an arrow on the bushing. (image below). That is where confusion comes if these bushings are different for each side.
2) Also do bolts are required to be renewed or old ones can be used if in good shape?
Imperial (12-05-2020)
Imperial (12-07-2020)
It looks okay to me. However, it is cheap and easy to replace so if you want to, definitely do it. Before you do, however, adjust the e-brake as it may help resolve the noise issue. Read here --> https://acurazine.com/forums/2g-rl-t...tening-772060/
I will inspect the parking brake cable as mentioned in the thread. The thing is that front and rear brakes, rotors were all serviced at the dealer(by the previous owner) last year. Many users in the thread report some metal clanking noise, but I hear a thump which mimics shock or bushing issue. Thank you.
Right Rear
ttribe
05-11-2024 09:17 PM
Eband27
1G CL Tires, Wheels, & Suspension
08-24-2011 05:49 PM
Arcticcl9
02-16-2005 11:37 AM
