a-spec wheel weight
unofficial HONDA rep
a-spec wheel weight
hey guys tried searching on here but no luck..just wondering if anyone knows the weight of the 18'' a-spec wheels?
I have never seen a weight for the 18" A-Specs. There is circumstantial evidence that they are 24-25 based on a Curry Acura email that says the MDX wheels are 4-5 lbs heavier, and another post from Touge that says an ebay dealer said the MDX wheels were 29 lbs.
There is another post where RonJon says the stock wheel weighs 27lbs
Has anyone called a dealer?
i do know the stock 17'' are about 24.5lbs and factory michelin tires are 26lbs , so i am trying to figure out the difference in the 18'' a-specs versus the 19'' rims i ordered along with tires.
How did you figure out the weight of the stock 17s? Did you weigh the combo and look up the tire weight?
Can anyone weigh their A-Spec, look up the tire weight and subtract so we can get a weight on A-Spec 18's.
I am keeping a spreadsheet of different wheels, weights, etc that have been fitted to the RL.
From Wikipedia:
Second Generation Acura RL (KB-1 and KB-2)
Conventional Wheels and Tires KB-1 (2005-2008) OEM Style Wheels
Made by Enkei (P/N 42700-SJA-A82) or Asahi (P/N 42700-SJA-A81)
Diameter and Width: 17" x 8"
Bolt Pattern: 5 x 120 mm
Offset: +55 mm
Hub Size: 64.1 mm
Lug Size: 14 mm x 1.5
Lug Style: Honda flat "mag seat" with washer
Lug Nut Wrench: 22 mm
OEM Lug Lock: Acura RL Non-PAX Wheel Lock P/N 08W42-SJA-200 (note this is a different part number than PAX wheel lug locks, and substituting the wrong lug seat is dangerous. PAX wheel lug locks are often sold at a discount, but do not fit conventional wheels properly.)
Est. Weight: 25 lbs
Tires: Michelin Pilot HX MXM4 245/50-17 98V Grand Touring class All Season Radials
Conventional Wheels and Tires KB-1 (2005-2008) Optional Accessory "A-Spec" Wheels
Diameter and Width: 18" x 8"
Offset: +55 mm
Hub Size: 64.1 mm
Est. Weight: 26 lbs
Tires: Michelin Pilot Sport A/S 245/45-18 96Y Ultra High Performance class All Season Radials
or Michelin Pilot Sport PS2 245/45-18 96Y Ultra High Performance class Summer Radials
Michelin PAX (run-flat)Optional Wheels and Tires (2006-2008)
Width and Diameter: 235 mm x 460 mm A ("A" is for Asymmetric indicating a PAX specific wheel)
Offset: TBD
Hub Size: 64.1 mm
Lug Style: Spherical seat
OEM Lug Lock: Acura RL PAX Wheel Lock P/N 08W42-SJA-200A (note this is a different part number than non-PAX wheel lug locks, and substituting the wrong lug seat is dangerous)
Est. Weight: 30 lbs
Tires: Michelin Pilot HX MXM4 245-680R460A 102V Grand Touring class PAX (run-flat) All Season Radials
or Michelin X-Ice 245-680R460A 102H Winter Tires
Conventional Wheels and Tires KB-2 (2009-TBD)
Offset: +55 mm
Hub Size: 64.1 mm
Est. Weight: 26 lbs
Tires: Michelin Pilot Sport A/S 245/45-18 96V Grand Touring class All Season Radials
Offset: +55 mm
Hub Size: 64.1 mm
Est. Weight: 25 lbs
Offset: +55 mm
Hub Size: 64.1 mm
Est. Weight: 26 lbs
Offset: TBD
Hub Size: 64.1 mm
Est. Weight: 30 lbs
Offset: +55 mm
Hub Size: 64.1 mm
Est. Weight: 26 lbs
Thanks.
I wrote that, based on research, personal experience and posts from here. As you can see I have not yet footnoted everything.
I was hoping to make it more accurate as time goes on. That is why all the weights are estimated.
EvilVirus
12-10-2015 07:38 PM
nuldabz
09-03-2015 05:49 PM
