spacers?
Old Apr 10, 2013 | 06:23 PM
CanadianRL's Avatar
spacers?
hello,
This question is for everyone running spacers on their RL. I currently have a 19*9 +35 rims on my car which doesn't clear my brakes in the front, so I have added a 6 mm spacer which just barely clears the brakes.
just for peace of mind, i thought i would increase the spacer size this summer, i wanted to run 17 mm, however, this involves rolling fenders and all, so i don't want to go that route.
I have found a 8 mm spacer which will give me some more clearance that i'm happy with, the only thing is with that spacer on the wheel nuts barely turn 5 turns. Is this safe? Does any have any experience with running spacers on this size or anything bigger.
Any input is appreciated, thanks in advance.
Old Apr 10, 2013 | 07:01 PM
BDoggPrelude's Avatar
5 turns is not enough. If you want peace of mind, buy wheels that fit your car properly.
Old Apr 10, 2013 | 10:25 PM
d1sturb3d119's Avatar
Mine's a TL and it is different but I got have spacers with studs pressed into it.... I've run those at autocross events too... DO NOT USE STEEL LUGS ON THAT! Buy aftermarket lugs as well. Aluminium lugs on aluminium spacers. Also use Lugs that are 6061-T6 which are forged.
http://www.evasivemotorsports.com/mm...s_Wheel_Spacer
http://passwordjdm.com/Lug-Nuts-Wheel-Studs-C1821.aspx
Old Aug 27, 2013 | 09:50 PM
Big Big Rick's Avatar
Ive heard that you can change to longer bolts
(but then use open ended lugs)
I would try to be resourceful and figure out the proper place to cut back the bolt after the lug is securely fastened
but that's just my novice idea
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
rockvilleTL
Sep 19, 2015 04:44 PM
yvr_tsx
Sep 15, 2015 01:14 PM
