Proper tire pressue
Proper tire pressue
Does anyone know the proper tire pressure for the A-Spec 18 inch wheels and 245/45/r18 tires? I recently installed aftermarket 18's in place of my stock 17's and I figure the tire pressure recommended for A-Spec cars is a good starting point.
Thanks!
Thanks!
teh CL (10-10-2019)
Latent car nut
Ummm, no; the pressure indications on the side wall of the tires has absolutely nothing to do with what is the appropriate pressure for any given car; that is just the maximum pressure which should be used in the tire.
Allow me to walk you through OPs post:
Sure we do, because as stated above the FACTORY specs for the factory tires are in the door on the sticker. Which is 100% accurate if you are running the OEM spec tire.
Here we realize OP not on factory wheels, and they are also NOT on factory spec tires AND they are looking for a "STARTING POINT"
Now, hopefully you are comprehending the situation at hand, I will walk you through the proper way to address tire pressure.
Leading off with a Google reference, since you seem like an all knowing and not searching type of member: https://mechanics.stackexchange.com/...on-stock-tires
Similar answer with more ad/spam: https://axleaddict.com/auto-repair/C...rmarket-Wheels
After reading that link, and now that we are all a little educated, lets rethink your approach and apply a little humility in the future.
Latent car nut
Ok, I'll bite. You realized what you just said right?
Ok, I'll try again in less words.
The sticker in the car is ONLY for OEM spec tires on OEM spec wheels on a NON modified car.
Since there are varying load/size/performance aspects of aftermarket tires, they all have different pressure needs.
The numbers on the tire are max for the weight rating of the tire
if you take the weight of the car and do the math you can get a starting point of the correct air pressure for that tires specification.
All that said, if you read the links (which you clearly still haven't) there are numerous methods to achieving the correct air pressure for non OEM spec scenarios which is what the OP is asking about.
Latent car nut
Interesting perspective, do you often find yourself wondering why everyone around you never understands?
Ok, this statement, the MAX PRESSURE indication on the sidewall of a tire has nothing to do with what is the appropriate pressure for any given tire on any given car.
Lets start with the basics, although exact in their size, you do realize that not all tires are the same right?
Each tire has a different load rating, traction spec, wear/mileage spec, and possibly rubber compound.
Although you are correct in that the numbers on those tires have nothing to do with the car, they have 100% everything to do with the tire and the application in which its applied.
Using those max numbers as a reference point, then applying the weight of the car you own will allow you to calculate the right air pressure.
For example, if you have a truck that weighs 8000lbs but you have a load rated tire that can work under a load 3 times that weight.
You take the max air pressure which is likely 90psi and reduce it to 30/35psi for daily travel.
Latent car nut
y'all are both right, but also both wrong.
Horsie is right in that for a laymen, looking simply at the sidewall to determine the proper tire pressure is not good enough (for OP)
Heavy is right in that TECHNICALLY his approach of taking into max weight rating and weight of car to calculate the pressure is an approach OP can take.
Heavy is wrong in that Horsie never mentioned the sticker so attacking him regarding that is not called for.
ALL IN ALL, both very smart people that are are getting at one another for no reason.
My sticker is SJA-T0 and does not list the 245/45R18 96Y. Not sure why that tire is shown. Your wheels are either 17 or 18 haha.
Question for the forum. 235/50R17 100W are not available in my country. Only 235/50R17 96W. I'd guess they are fine? Since the other spec tire load is the same right?
