Alignment problems
Alignment problems
I need some advice on my 05RL with approx 38k miles. For about three months (especially on the highway it seems) it has been tracking to the right more that I think is normal. If you let go of the steering wheel, within 2-3 seconds you're slowly changing lanes to the right. It's biased to the right enough where it seems like I am intentionally changing lanes (if this helps describe it) within a five second timeframe. Everything about the alignment is within specifications (two or three trips to NTB) with the possible exception of the left caster (2.6-2.7 degrees). The right caster is 2.4 degrees.
I'm curious to know how anyone elses' RL "tracks" on the highway. Trust me when I tell you it's NOT the crown in the road(s), the tires (started on OEM Michelins and just put Continnential DWS Extremes on) and/or a strong crosswind.
Yeah, that's what the alignment place has been telling me but I feel like that is a "work-around". I've played with just 1-2lbs more in the RH front and didn't seem to make a difference. I'll put 3 pounds in the front and a couple more in the back and see what happens. Going to do it right now, keep fingers crossed!
SidhuSaaB
05-30-2020 12:40 AM
