I recently bought a used 05 RL. It has an aspec kit which is eating inside of tires. Mainly in rear. Shop tells me they can align but wont fix problem, that I need to go back to stock suspension. I know this can't be. Does anyone know what parts I need to buy to fix alignment and where I can find them? I live hr South of Houston. These guys only work on trucks.
Ive taken it to 3 shops aound here all refer me to another. One refered to body shop to check frame. Frame is perfect. I guess I need to go to houston. Any recommendations
Recent update. Went to local Honda dealership today. They told me I need a front and rear camber kit because vehicle has been lowered to aspec suspension. Finding parts on eBay.
H&R`s here, no issues with tire wear.
Feels that somehow you have bumped to people who dont know anything about wheel alignments and how its done or how to check out if there is some faults.
I know South Houston is a shit hole, no offense OP, but WTF is wrong with the shops in your area? This is such a simple issue with such a simple solution.
EDIT: UNLESS, maybe your car has a custom camber kit or modified ball joints.
Honda dealer says aspec suspension on mine is not factory. Im thinking whoever did it did a really crappy job and then just traded car, then I bought it.
I have an all stock 2005 RL that has rear wheel alignment problem, wears the inside of rear tires. Tire shop has done max adjustment and still outside of specs. They suggested aftermarket rear camber kit but can't find one. Called Acura dealer and they suggested going to forums to find. Any help, suggestions would be great.
possibly some suspension damage from curbing, pothole or accident
sooooooooooooo I have an 2006 RL with the same rear -2 camber issue in the rear. Acura Dealership Service Dept said to check out the forums or buy aftermarket parts. SPC & Ingalls don't make anything for our cars...what did you end up doing Mike?
You would think the shops would know their head from a hole in the ground if they are a quality alignment shop. If it doesn't meet spec, then it needs to be adjusted. If it runs out of adjustment, then something is bend or worn out. Rubber parts don't last forever, especially in suspensions.
Take your car to the place where the top line cars (Mercedes, Lexus, Ferrari etc) go to get alignments and stop dinking around with people that only know Fords, Chevy's, Toyotas etc.
if cambers out then you have control arm issues which isn't uncommon in acuras and it happens to suck that you can't just get a camber kit for the rear or front for that matter. if it were me id take it to an ACURA dealer and ask for the most experienced tech to take a look at and get a loaner car so they can have the proper time to look at it and do the proper measurements. it helps when the tech has time to look at it and doesn't have anyone breathing down his neck for an answer
Coincidentally, I'm noticing heavy inside tire wear. One tire is way worse than the others and in fact, was the reason why I had to buy two new tires.
I never really noticed it before and not sure what wheel is causing it because I get my tires rotated every time I get my car serviced and only noticed it a few weeks ago when my car was parked at an angle.
My car is completely stock, I got it brand new and never curbed it as far as I can remember. I'm taking it in to do the A13 service and an alignment. I've never had my car aligned ever btw, since I got it in 2006. It still has the factory brakes at 87k miles and every time the dealer looks at them, they tell me I'm still good.
Here's to hoping I have a simple toe alignment problem.
Its No Real Surprise You've Got Uneven Tire Wear Seeing As You've Never Had It Aligned In 7 Years And Over 87k Miles On It. Seeing As Acura Recommends Alignments Every 12months/15,000miles. Even So, Yours Is Probably Only A Toe Issue.
Alignment wasn't that bad with most readings within spec, although they did adjust camber and toe a little. It's a bit puzzling because the tire wear was really bad. I'm hoping whatever adjustment they did will fix the tire wear problem.
They found a cracked motor mount that will be replaced when I do the timing belt (free of charge except for the part price) and my brakes, at 87k miles, still have more than 2mm! The advisor asked me if I ever slam on the brakes...
Hello all... new to this forum. Couldn't find a more recent thread so thought I'd add my question here. Have an 05 RL and I'm looking to upgrade to aspec suspension. Acura no longer sells the kit 08w60-sja-200 and searching online only uncovers parts for three corners minus the front driver. Anyone know of where I might be able to find the complete kit? Thanks!
So I recently installed A front camber kit on my 2006 acura RL.. The part I used was the upper control arm camber kit from a 2009 acura TL and it fit perfectly!!! I have Megan Racing coilovers currently installed and after lowering the car I was at a negative 3, But once I installed the new camber kit I'm now at -.06 in which I can still go out a little more.. but It 09 TL camber kit on my 06 RL... perfect fit!!!
definitely feels great knowing my car and tires will be happy 😊
front lower control arms and sway bar bushings and links be the main problem. I have a 05 RL
