XM dropping every now and then
Old Dec 1, 2005 | 12:09 PM
Nocturnal's Avatar
the last few days I've noticed that XM will drop for a second or so for no apparent reason every now and then. This morning it was on one of the comedy channels, last night chrome I think. There's no static when this happens. As you probably know static is heard when the sat. signal is lost. this seems different.
Anyone?
Old Dec 1, 2005 | 12:21 PM
vp911's Avatar
I have had a similar problem the last couple days I have noticed - except it will just go quiet, no static.
Old Dec 1, 2005 | 12:45 PM
Nocturnal's Avatar
Ok, so we're experiencing the same then
thanks for responding.
Old Dec 1, 2005 | 02:47 PM
jftjr's Avatar
'06 RL
If you have a large object to your South, or are driving along a tree-lined road, it often will drop. You need a decently clear LOS to the southern horizon to get satellite signal.
I live in a pretty woodsy area, and it will drop frequently if there's a lot of trees between my car and the Southern horizon.
In my experience, you don't get static when it drops signal -- it just mutes. Since it's digital, I don't imagine that it would actually play static. If you're on the "Audio" screen when it happens, it will display "No Signal."
Old Dec 1, 2005 | 04:21 PM
stingerbtry's Avatar
Same here. Mines been doing it all day. I thought it was just because it was raining but if others are getting it too then it may be more widespread/bigger.
Old Dec 1, 2005 | 04:31 PM
vp911's Avatar
again
Old Dec 1, 2005 | 06:15 PM
Nocturnal's Avatar
I know the difference between 'regular' dropouts and the problem I'm describing. There are two overpasses that I go under to/from work. In the morning the XM will hiss for just a second right after I go underneath. On the way home it doesn't do that. To me that means that the XM antenna is not placed very well. If there's a signal somewhere I should be able to receive it, doesn't matter what direction the car is pointing. Anyway, that's a different issue.
I agree there shouldn't be any static when the signal drops so I think they added an artificial white noise generator for these conditions to make XM more like 'regular' radio.
In any case, the drops I was reporting can happen anywhere. If they always happened in the same place I would have reported that you know
Old Dec 1, 2005 | 06:19 PM
vp911's Avatar
It IS a possibility that at the time this has happened to you (with the hissing noise) that you were rcv signal from a land based signal transmitter. Many major cities have these because the antenna on the car cannot always get the signal from the sat.
Old Dec 1, 2005 | 06:57 PM
Nocturnal's Avatar
Hmm, that could be, yes. Makes it even stranger that the signal would fail though.
Old Dec 1, 2005 | 07:29 PM
vp911's Avatar
^ True, dunno
Usmcgrunt47
Oct 13, 2023 09:35 PM
emailnatec
29
Sep 28, 2018 04:27 PM
bluetl04
Aug 16, 2016 02:49 PM
us285126
Oct 2, 2015 02:03 PM
4drviper
Sep 23, 2015 07:42 PM
