Subwoofer upgrade
Old Jan 21, 2012 | 09:54 PM
Zelaya's Avatar
2012 TL SH-AWD
Subwoofer upgrade
Hi guys, been doing research for past hour without any success. Ive been thinking on upgrading my OEM sub for one single 10' JL Audio W7 just to add a bit of bass. I'm sure I will need to add a amp to give some juice. I really don't want to sacrifice my trunk space by adding a bulky box. Have someone done this on their RL and if you guys can provide photos of their setup that will be great.
BTW, I will have to look for a professional audio installer in NOVA or MD area to do this project.
Old Jan 21, 2012 | 10:07 PM
23109VC's Avatar
is there any way to just upgrade the existing woofer with a higher quality unit? but just leave everything else the same? that would be my suggestion.. if possible. not sure if it is that easy though...
my gut is that unless there is some plug n play sub you can swap in... trying to put in a third party sub/amp that woudl work right with the existing Acura sound system / noise cancellation system / etc.. might be a hassle.
luckly for me, the factory system is plenty for me.
Old Jan 21, 2012 | 10:54 PM
Zelaya's Avatar
2012 TL SH-AWD
I'm afraid I will have to settle for what I have right now.
Old Jan 21, 2012 | 11:10 PM
HEAVY_RL's Avatar
There are plenty of threads on how to put and amp in on the factory wires and how to disable the noise cancellation.
So is the question here really about a stealth install?
If so, the question really comes down to budget, because there is some really creative ways to put systems in now a days.
Old Jan 22, 2012 | 05:48 AM
Sniffles's Avatar
I tried to just upgrade the factory sub but the guy said we need a thin sub to drop it in since our factory sub is very thin. I didn't feel like dropping too much and they upgraded my 10in JL to 12in for free so I didn't complain. I figured I can always take the box and sub with me whenever I sell the car =)
Old Jan 22, 2012 | 05:34 PM
Carbon Legend's Avatar
here are some free air subwoofers that could work There is quite a bit listed. I plan on tackling this in the sping since i could use the truck space. Possibly mount the amp down in the spare tire well. you may need to remove the carpeted area that covers the rear deck if you get a deeper sub
Infinity 100-9
Kicker 10C104
JL ZR800-CW- 8" sub possibly make a adapter to fit in factory hole
Alpine SWR-T10 Shallow Mount Type R 10" sub
Old Jan 22, 2012 | 06:25 PM
oo7spy's Avatar
Get a small amp and put it inside the quarter panel behind the lining. Then put the speaker backed up to the quarter panel. One speaker like either of mine will leave plenty of space.
Space was a requirement and keeping the spare accessible was too. I have changed a tire before with a huge double 12" box and it was not fun. I have changed a tire with this setup and praised my own forethought.
Old Jan 22, 2012 | 08:40 PM
Zelaya's Avatar
2012 TL SH-AWD
Thanks for the information guys...
Hey 007, care to share what type of boxes do you have. Will the boxes that you have can fit W7 in 10 inch ? that's very clean setup. Did you bolted the boxes to the chassis.
Old Jan 22, 2012 | 08:51 PM
oo7spy's Avatar
Made them myself. If I had to do it again, I would use fiber glass. However, I had never worked with the stuff before and was nervous to try. If you are going to have a professional do it, that is really the only way to go. They will agree and will insist to do it that way. It is a much cleaner and compact way to go.
As for keeping them down, I used velcro, believe it or not. This was a big question I had throughout the whole process because I thought most of the weight would be at the front of the speaker. However, later on I realized the majority of the weight lies in the coil and magnet which is at the back of the speaker. This keeps the boxes from titling forward. Still, I used contact cement to hold some industrial velcro to the liner and the bottom of the box. I did the same thing for the amp.
Old Jan 22, 2012 | 09:03 PM
Zelaya's Avatar
2012 TL SH-AWD
I see.....I need to get the dimension that is require for the JL Audio woofers in order to make the boxes that small. Maybe I can do 1 12' W7....I know this woofers can through good bass punch.
Old Jan 22, 2012 | 09:41 PM
DiabloSVRacer's Avatar
oo7spy, if they are gone one day, don't look at me!
jus kiddin why didn't bolt it down instead?
Old Jan 22, 2012 | 10:51 PM
oo7spy's Avatar
Just leave the car. The speakers are old.
I thought about bolting it down, but that required more work than necessary.
Old Jan 23, 2012 | 07:53 AM
HEAVY_RL's Avatar
Unless you build a false floor, "bolting it down" would result in putting holes in the trunk.
Back in the day my Honda civic looked like swish cheese before I smartened up.
Old Jan 23, 2012 | 09:00 AM
oo7spy's Avatar
With 3"x4" of industrial strength Velcro cemented to the liner, you would think it is bolted down if you tried to pull them up and didn't know any better.
Old Jan 23, 2012 | 09:27 AM
HEAVY_RL's Avatar
Yeah, I had one of those infinity tool bags in my trunk once, it had a 12x6 piece of Velcro on the bottom and I thought i was going to rip the liner out of the trunk pulling it out.
Old Jan 23, 2012 | 02:52 PM
lol velcro = next best thing to super glue?
Old Jan 23, 2012 | 05:00 PM
HEAVY_RL's Avatar
Velcro doesn't taste as good.
Old Jan 23, 2012 | 10:20 PM
oo7spy's Avatar
I tried huffing Velcro once, nothing happened. One more thing glue is better for.
Old Jan 24, 2012 | 09:54 AM
EL19's Avatar
Velcro is the way to go.
Zelaya- I have one 10" W7 and it packs PLENTY of bass. If you're going for a sublte increase in bass that would be the way to go.
I actually have my amp mounted under the passenger front seat. Noone can tell its there, it doesnt impede the movement of the seat either. I havent really had an issue with trunk space either with the 10" woofer back there. Changing tires was easy too. Not having an amp back there is the best part. The sub comes out easy.
If you were going for a factory replacement, Carbon Legend recommended great free air subwoofers but then I'd be concerned about the rear deck rattling to shit.
You could go with the small subwoofers that have the amps already in them. They save ALOT of space
Old Jan 24, 2012 | 10:34 AM
Zelaya's Avatar
2012 TL SH-AWD
I need to listen to yours and see if one W7 is enough. What type of music you listen?
Old Jan 24, 2012 | 10:47 AM
HEAVY_RL's Avatar
if it were me, I would try something like this:
http://www.sonicelectronix.com/item_...2-10CVT82.html
See how it performs on the stock set up, and then if need be upgrade the amp.
It all depends on your taste and what you want to hear.
Old Jan 24, 2012 | 02:28 PM
EL19's Avatar
I listen to everything except country music I have the leads from the stock amp going to the aftermarket JL 500.1 . I have the JL amp gain turned up to maybe 35% and then since I can control the bass with the factory subwoofer EQ setting, I have that on -3. I can give people headaches or heart palpatations with that setup alone LOL
Old Jan 24, 2012 | 05:36 PM
i like to listen to that pop music Britney spears!!!!!!!
i roll all my windows down put the rear window and windshied shade up! lol
opps i did it again...
Old Jan 24, 2012 | 06:01 PM
HEAVY_RL's Avatar
a nicely powered W7 is a great speaker... I owned one 12w7 on a 1000 watts and it was so loud.
Old Jan 24, 2012 | 06:17 PM
Zelaya's Avatar
2012 TL SH-AWD
Maybe if you come to this Saturday meet I can listen to it. I can bring my rancheras,salsa,merengue cd's
Old Jan 24, 2012 | 07:18 PM
HEAVY_RL's Avatar
LoL, sorry to disappoint bro but turning 30 reduced my sound system to usa spec, nav tool, and iPhone.
Old Jan 25, 2012 | 10:30 AM
EL19's Avatar
I'll be there this saturday. I usually listen to salsa on my pandora.
Dam man, I couldnt do it!
Old Feb 10, 2012 | 02:12 AM
uradumbass27's Avatar
5th Gear
i might just have to try this
Old Feb 10, 2012 | 07:26 AM
HEAVY_RL's Avatar
I said the same thing at 25... when I was flipping quarters off the roof of my car.
Old Feb 20, 2012 | 06:53 PM
DXplicitOne's Avatar
I can build a custom enclosure for you if you want one and ship it to you. I can do it to any vehicle really just need to tell me where you want sub placement and ill take care of the rest. If your interested let me know and ill discuss the details with you. I have photos of my old system on here already which isnt really stealthy as you want. But my last simple sub additional was in a Lexus RX330 and might fit your needs.
Size:  77.8 KBName:  DSC00649.jpg
I can do it for any size sub you want and the air space you desire.
Actually... is this losing too much trunk space for you?
This was my old system and then i upgraded and rebuilt and it has been in my car un-carpeted for months now as im not sure im keeping the car or not. If your interested in a setup that takes the same amount of space as above minus the plexi then my 1 - 10" Sundown might be right up your alley. Just a thought.
Old Feb 21, 2012 | 08:33 AM
oo7spy's Avatar
That's nice work! What's holding the Lexus' box down?
Old Feb 21, 2012 | 08:48 AM
Zelaya's Avatar
2012 TL SH-AWD
Nice work Dxplicitome! I'm sure shipping this enclosure should cost a arm and leg.So far I've narrow on doing one W7 10' with a JL audio 500/1 amp but I'm putting this mod on my last priorities. It seems almost every member here has done this mod on their vehicles and tab it from the factory amp.
Old Feb 21, 2012 | 10:40 AM
ojmcduffie's Avatar
Talk about a CLEEEEEAN install...
Old Feb 21, 2012 | 12:49 PM
HEAVY_RL's Avatar
Thats weak... I do werk.
Old Feb 21, 2012 | 01:02 PM
Zelaya's Avatar
2012 TL SH-AWD
hahahahaaha, you must be bored Heavy
Old Feb 21, 2012 | 05:26 PM
oo7spy - The Lexus box is not held down by anything and it doesnt move. A combination of the weight from the box and sub as well as the wide foot print and carpet to carpet friction on the bottom keeps it right where you see it. She didnt want any holes of any sort in any panels etc etc when doing this so no mount for that one.
Zelaya - Shipping the enclosure may be less than you think. I use a business Fedex account to ship items like this and its not that heavy given that 70-80% of the enclosure is fiberglass. Just throwing it out there. If you do move forward with the install you will want to tap off the sub signal to maintain the sub level control in the OEM head unit and dont forget to disable the noise cancelling unit.
ojmcduffie - Thanks.
HEAVY_RL - Shits ill!
Old Feb 21, 2012 | 05:35 PM
HEAVY_RL's Avatar
haha, I had a little time on my hands today.
Old Feb 21, 2012 | 05:52 PM
Zelaya's Avatar
2012 TL SH-AWD
PM your number to call you.
mlody
Dec 4, 2019 02:11 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
kb1rl
Sep 30, 2015 10:17 AM
thegipper
Sep 28, 2015 01:01 PM
jmaxima03
Sep 27, 2015 10:22 AM
