The Secret Screen Research Thread
Old Jun 5, 2010 | 03:30 PM
jmlaser's Avatar
Note: any changes made in the following areas are made at your own risk. Please write down any information you change and be aware that changing items MAY void your warranty. For those who like to play read on....
This thread was started as a gathering place for people to discuss the hidden screens of the NAVI system, thier uses and any related material to them.
As you may or may not know pushing Menu + Cancel + Map/Guide for a few seconds
will access the hidden NAVI screens.
more to come......
Old Jun 6, 2010 | 12:26 AM
HEAVY_RL's Avatar
got my attention...
Old Jun 6, 2010 | 03:10 AM
TampaRLX-SH's Avatar
Torch & Pitchfork Posse
These are the diagnostic screens. They have been know and discussed for several years.
Old Jun 6, 2010 | 05:55 AM
christopher1's Avatar
this is old news..
i use it to clear info or set my mic but its best left alone!!
Old Jun 6, 2010 | 11:43 PM
jmlaser's Avatar
The screens found are as follows and can be accessed once the Boot screen has loaded any time the map is displayed
Map/Guide . . . Menu
Cancel
Hold these three for four seconds
Left Column
Navi Screen
Unit Check
Car Status
F-Can
Coverage Area
Right Column
GPS Information
Yaw Rate
Tire Calibrate
Functional Setup
Version
XM( HIP)
I understand that this has been discussed before. I am not reinventing the wheel. This thread is created to compile all the information in one place and to discuss what we decide to change if any....
Anyone with Dealer explanations or experience with these settings and screens input is highly welcomed
Old Jun 7, 2010 | 05:17 AM
owners should...
leave it alone, unless you know what you are doing!! if you mess some setting up then you have to return to the dealer to correct it.
Old Jun 7, 2010 | 06:44 AM
poppintec's Avatar
can codes be cleared through this screen?
Old Jun 7, 2010 | 09:37 PM
lstevennl's Avatar
codes can only be cleared through the OBD2 port or by disconnecting the battery for a brief period
Old Jun 8, 2010 | 01:38 AM
Blazing GT's Avatar
this
Old Jun 8, 2010 | 08:14 AM
HEAVY_RL's Avatar
Old Jun 8, 2010 | 06:00 PM
jmlaser's Avatar
Engine codes cannot be cleared thru this screen.
I was however able to clear some erroneous TPMS notifications the system would not allow to be deleted in normal mode. I was able to clear these in the XM (HIP) menu.
Please do not continue to post the DO NOT mess with these settings type posts. I have made it clear that you should not mess with them unless you know what you are doing OR ACCEPT THE RESPONSIBILITY FOR CHANGING THEM.
I am trying to get people that DO understand what these screens do or have experimented with these settings to share their experiences here.
Thanks for your cooperation and understanding
Old Jun 8, 2010 | 07:30 PM
please do not post..
info that could harm our RL. if an owner does try something that will cost him money and alot of explaining to the dealer!!!
Old Jun 8, 2010 | 09:42 PM
jmlaser's Avatar
Christopher
Please remove or delete your post.
The information is only harmful if you use it incorrectly. THATS why this thread was started. To clarify what is helpful/safe and what is not.
We should not hide information from people just to protect themselves from being idiots. If you are responsible with the information you are given you are fine. If not you deserve a trip to the dealer.
So again, If you want to post positive information please do so,... If not please do not post anymore post such as
"DO not post this" or a moderator will be contacted.
This community should be a helpful resource. We should not be sheltered like childeren.
Feb 25, 2020 09:57 AM
vpasla1
Sep 17, 2016 07:24 PM
tallyrlx
3G RLX Audio, Bluetooth, Electronics & Navigation
Feb 26, 2016 03:44 PM
iesu3423
Oct 6, 2015 06:54 PM
