rear speaker deck
Old Nov 22, 2010 | 06:06 PM
robgen's Avatar
rear speaker deck
i have an 06' acura rl and i am trying to change the speakers on the rear deck but i can not figure out how to remove it. also, does anyone know how to hook up an amp through the stock sub channel with the factory radio?
Old Jan 9, 2011 | 04:02 PM
golfpro22's Avatar
9th Gear
Did you figure this out? I blew my speakers today and need to replace them. Thanks!
Old Jan 18, 2011 | 11:38 AM
Real Legend's Avatar
the line driver (Audio Control LC6) that i used had signal interference with Sub line i use the door speaker line (line=audio plugs) for a signal and the LC6 did the rest by cleaning up any static interference. You dont need to use LC6 but its highly recommended by me.
Old Feb 19, 2011 | 05:45 PM
oo7spy's Avatar
I plan on using a PAC SNI-15 line output converter. It takes the sub signal through a buffer and transformer then outputs a RCA output to the amplifier. The buffer is supposed to isolate any resistance or interference from the speaker line, so the sub should perform the exact same. We'll see though. Do let us know if you find out anything about removing the rear deck.
Does anyone know what the 4 main speakers' (front and back) sizes are? Also, I have heard they are 2 ohm and wanted to know if anyone could confirm that.
Feb 25, 2020 09:57 AM
akbears15
15
Nov 5, 2015 07:06 AM
Dunnik
Sep 15, 2015 11:52 PM
Pegon95
Sep 15, 2015 01:54 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
