A Possible Electric Short?
Old Aug 6, 2012 | 01:01 PM
Chans's Avatar
This all started about a week ago. I would notice that while driving, my radio would "beep" and then turn off. I couldnt turn it back on. I had to wait until it "beeped" and came on again. I also noticed that for a while I had no radio control from my steering wheel. To make any audio selection, I had to utilize the knob.
Fast forward to last night. I was driving and I noticed that my head lights flickered, followed by the beep and then my nav screen went black. This all lasted for about 1 sec and then everything went back to normal.
This is becoming more routine and its bugging me. Is anyone familiar with this issue?
Old Aug 6, 2012 | 01:43 PM
oo7spy's Avatar
Loose battery cable. Most likely negative.
Old Aug 6, 2012 | 02:59 PM
HEAVY_RL's Avatar
step 1. check battery
step 2. post up here...
Old Aug 6, 2012 | 03:13 PM
tsk, tsk, tsk....
you're slacking!
Old Aug 6, 2012 | 07:09 PM
Chans's Avatar
Its not the cable. I replaced that a while back when It kept corroding.
Old Aug 7, 2012 | 10:27 AM
HEAVY_RL's Avatar
tsk, tsk, tsk....
you're slacking!
trying to ease back in.
HEAVY_RL's Avatar
corrosion could be a sign of a loose connection
Old Aug 10, 2012 | 12:28 PM
Chans's Avatar
Yeah, which is why I replaced it. It doesnt corrode anymore so Im assuming that the issue is something else. I did notice that it gives the most problems during the mid-day. 100 plus degrees and my radio acts an a$$. Im kinda leaning towards the battery now.
Old Aug 10, 2012 | 02:48 PM
oo7spy's Avatar
So the connections for both negative and positive cables are secure on both ends, i.e. all four connections? There should be no movement of the cable on the terminal.
Old Sep 21, 2012 | 09:42 AM
Chans's Avatar
Yeah it was the battery. The negative terminal was leaking which caused the corrosion and the electrical randomness. After I replaced the battery, everything was fine.
Old Nov 11, 2012 | 02:53 PM
HKM2010's Avatar
3rd Gear
Please help with slowly dying battery on 2005 RL.
Battery unable to crank up by end of day, by 2nd day totally dead. Live in Fargo, very cold lately, park outside at work, in garage at home.
1. Acura dealer in Minneapolis said HFL module went bad, replaced $850, good for 2-3 days.
2. Local auto shop said parasitic drain from autostart, 1.5 Amps, unhooked it, again good only for 2-3 days.
3. Battery replaced last year.
After reading this thread, noticed my negative terminal was loose when jump starting.
Welcome any suggestions, ? bad fuse, ? worn out wire, ? bad battery
Wife's car, she is pretty upset finding out car doesn't start after work when temp is 24F.
Old Nov 11, 2012 | 04:13 PM
HEAVY_RL's Avatar
have you replaced the battery and the terminal?
Old Nov 12, 2012 | 04:25 PM
HKM2010's Avatar
3rd Gear
Giong to replace battery today. Hope they can replace the terminal too or tighten it good. New battery might be cheaper way to try than pay $100+ diagnostic fee each time.
Jul 16, 2017 07:33 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
