Opening all 4 doors from the driver side door handle
Hey Guys,
Can someone provide step by step instructions on how to opening all 4 doors from the driver side door handle? I know that the passenger side door handle has this feature built-in, but I'd like to open all 4 doors from the driver side as well.
This should be possible via the MFD by selecting Keyless Access Setup > Door Lock, and change the setting to All Doors, however I am having trouble getting to the Keyless Access Setup option.
Thanks,
D
Thanks,
D
It is all in the manual. You will need to go to the pertinent sections because there are pictures that go along with the text that make it much more clear.
You can change the display and
customize your vehicle control
settings by pressing the SEL/RESET
or INFO buttons on the right side of
the steering wheel.
Door Unlock Mode
To select whether the driver’s door
or all doors unlock when you open
the driver’s door with the remote or
by grabbing the door handle (while
carrying the remote), follow these
instructions:
While the multi-information display
is in the KEYLESS ACCESS SETUP
screen of the CUSTOMIZE GROUP,
press the SEL/RESET button. The
screen changes to the above display.
Press the SEL/RESET button. The
screen changes as shown above.
Select DRIVER DOOR ONLY or
ALL DOORS by pressing the INFO
( / ) button, then press the SEL/
RESET button to enter your
selection.
When your choice is set, you will see
the above display for several seconds,
then the screen goes back to
CUSTOMIZE ENTRY.
the steering wheel.
Door Unlock Mode
instructions:
selection.
CUSTOMIZE ENTRY.
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
sockr1
Oct 1, 2015 01:31 AM
