Nav not working
Old Jun 30, 2012 | 05:07 PM
Raj18's Avatar
Nav not working
Have a 05 RL in which the driver side door handle sensor stopped working so now the nav system doesn't work (blank screen and the buttons do not respond) and also the door locks do not work and the fuel filler door button doesn't work. Has anyone has this happen to them and know what is the cause? Got a quote from the dealer to replace the door handle, but they cannot tell me if that will fix the nav not working issue as well? Any help or guidance would be appreciated!!
Old Jul 1, 2012 | 12:23 AM
Matt W's Avatar
I know when I went to install my NavTool the GPS Unit 24pin harness had a bunch of wires where the jacket had broke (probably during the winter or from 7 years of use lol) leaving the copper part exposed, It was like 8 wires and them touching could have caused some problems. I wrapped it up with Wiretape the best I could.
Is the screen backlight on and can you still operate the Radio using the XM/CD and (1,2,3,4,5,6) buttons? If you can then something could be wrong with the wiring to the GPS unit.
Old Jul 1, 2012 | 09:44 AM
white05rl's Avatar
Have you checked the battery? Might sound like a long-shot, but electronic gremlins (when there are several of them at one time) usually turn out to be the battery.
Old Jul 1, 2012 | 11:15 PM
mayflowerman's Avatar
Do a search on the Navi. Lot's of threads about sending the unit back to Alpine for repair. Cost is about $400.
Old Jul 2, 2012 | 01:25 AM
Matt W's Avatar
I know that when I had cut the accessory power to the navigation unit in the trunk (8 pin connector) the navigation unit would not operate (backlight on screen but that was it) no nav buttons, info, multi directional knob etc... but I could operate the radio using the CD..XM buttons. Don't think this is the issue but its worth checking out considering how easy it is to remove the panels in the trunk.
Old Jul 23, 2012 | 11:09 PM
When my Navi went out I had the same issue. Screen backlit but no display. No other feathers/buttons worked except for the xm and radio memory buttons. Sounds like a job for Apline.
Old Jan 14, 2013 | 01:03 PM
harvey3121's Avatar
2005 Acura RL - Door lock/Fuel Lid Button & Nav
I have an Acura RL 2005 with the same problem as Raj18. My door lock and fuel filler buttons do not work and the NAV screen is dark.
Does anyone know how to fix?
Thanks,
harvey3121
Old Jan 14, 2013 | 02:10 PM
oo7spy's Avatar
Check your fuses.
Old Jun 12, 2013 | 05:25 AM
clemente007uss's Avatar
well to fix the dark screen for ur navi all u have to do is replace ur communication fuse
Old Jun 12, 2013 | 08:47 AM
HEAVY_RL's Avatar
did anyone check the fuses?
koju01
ILX Audio, Bluetooth, Electronics & Navigation
Dec 14, 2015 02:17 PM
Rocktman1
Sep 19, 2015 05:58 PM
acurajj
Sep 19, 2015 03:47 PM
Barb Jackson
Sep 15, 2015 02:27 PM
andysinnh
Sep 5, 2015 11:38 PM
