MP3's from iTunes- won't work-help help
Old Sep 22, 2005 | 10:32 PM
agroves's Avatar
Does anyone have experience getting their MP3's to play in the RL? I purchased a bunch of music MP3's from iTunes and tried burning it to cd. Default settings convert the music to CD-A format which only allows about 20 songs on a CD. I want to use the MP3 layout but the iTunes interface says I can't burn MP3's to CD. Then I burned using the data format and copied then pasted/burned to cd- the RL doesn't read the file structure and ejects the disk within seconds of putting it in.
Has anyone else gotten the RL to play MP3's? If so, how did you create your CD?
Old Sep 22, 2005 | 10:37 PM
vp911's Avatar
In your situation - you would have to burn the songs to the CD then rip them onto the computer (tucows.com or download.com you can find something for ripping cd to mp3s).
Then in order to burn an mp3 cd you need to simply burn the mp3 files into a blank cd - using a data format, NOT a music or specific MP3 format.
Old Sep 23, 2005 | 12:06 AM
jhr3uva90's Avatar
Did you buy the songs from the iTunes Music Store? If so, that's your first problem. Songs bought from the store are NOT in the MP3 format. Instead, they are in the AAC format with DRM copy protection technology added. You would have to burn a "traditional" CD from those songs and then re-rip them onto your computer's hard drive as MP3's. After that, you can burn the songs as MP3's, albeit at a slightly lower sound quality than their original AAC format.
Old Sep 23, 2005 | 12:07 AM
jhr3uva90's Avatar
One more thing, please make sure you have set iTunes to import your songs as MP3's, if you intend to use iTunes.
Old Sep 23, 2005 | 07:11 AM
vp911's Avatar
It doesnt matter if he bought them from itunes or napster or yahoo music. They are all in an encrypted format that he would have to burn to a CD then rip to mp3.
Old Sep 23, 2005 | 08:56 AM
Rich in NC's Avatar
Unemployed or retired?
Exactly.
Files from iTunes are in a m4p format that is not rcognized by an mp3 player. The only way around it that I know of is to go to a standard cd audio burn and then a rip to mp3
Old Sep 23, 2005 | 09:05 AM
spacklebucket's Avatar
I think he may have been referring to importing music from standard CDs. The default setting in iTunes for importing CDs needs to be changed to MP3.
Old Sep 27, 2005 | 06:47 PM
agroves's Avatar
Thank you all for your responses. I was downloading in m4p format. Didn't know I needed to RIP to MP3. Does anybody have a RIP utility recomendation. I was buying them from iTunes Music Store.
THanks again for the help.
Old Sep 27, 2005 | 06:51 PM
vp911's Avatar
http://www.tucows.com/get/371726_140091
Old Sep 27, 2005 | 08:47 PM
jhr3uva90's Avatar
Or you can just make a CD and then import the CD using iTunes. Just make sure iTunes is set to import as an MP3.
Old Sep 27, 2005 | 10:10 PM
Rich in NC's Avatar
As far as I know m4p is a protected format. That means you may need to create a regular CD audio file from mp4 which iTunes will do. Then you can take that CD and rip it to mp3 which iTunes will also do. That is how I do it.
Old Sep 27, 2005 | 11:06 PM
jhr3uva90's Avatar
The m4p (AAC) isn't an inherently protected format or codec, but songs purchased from the iTunes Music Store have Digital Rights Management copy protection added. Fortunately, the DRM is lenient enough to allow you to make a CD and then import it in iTunes without additional software.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
eastsideride
Oct 15, 2015 04:26 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
mars
Sep 28, 2015 11:03 AM
