left headlight flicker but turns on with the switch
Old Sep 6, 2017 | 03:28 PM
fuzzysig's Avatar
so I looked around at the other threads about light flicker and there are everything from replacing the bulb to afs module which pretty much covers the whole system
which doesn't point me to a problem with mine
mine flickers when I go over bumps
it turns off
then I flip the switch off and on and its back on until I hit bumps on the road( when I was driving on the freeway it turned off about 5 times and I turn it back on with the switch and it comes on every time
my AFS light was also on for 3 days and then turned off on its own yesterday during a long drive on the freeway
I feel like theres a loose connection somewhere but maybe someone can suggest me where would be the most common place and where I should start checking to save some time
PS: even though ive been getting all these stupid issues the car has been pretty reliable overall and a solid driver on the freeway
Old Sep 6, 2017 | 07:45 PM
projektvertx's Avatar
I hate to repeat what you've already suggested, but it sounds like a typical loose connection to me. I had a similar issue with the D2S projectors on my Camry where it would come off and on at it's own content, in similar situations to you. Turns out the ballast connection wasn't clipped on well.
I honestly feel bad for you considering how much bad luck you've been having with this car man...
Old Sep 6, 2017 | 09:43 PM
GhostTL09's Avatar
if not a loose connection then you have a ballast going bad...pop the hood clean and re-attach connections
Old Sep 7, 2017 | 08:45 PM
fuzzysig's Avatar
i had worse lol
i owned integras for last 10 or so years...
Old Sep 8, 2017 | 06:35 AM
i dont think luck has anything to do with machines and or electrical components.
I've had my fair share of mechanical problems (that I caused myself)....
one of the TL guys just recently bought an '13+ S4, but now has to replace the clutch.
cars are machines. machines have moving parts. moving parts fail.
as do electrical components.
it's just what happens. and we do our best to repair or replace parts.
Old Sep 8, 2017 | 03:36 PM
truonghthe's Avatar
^^^ you got an Audi?
Old Sep 12, 2017 | 01:43 PM
fuzzysig's Avatar
wheres the ground for the headlights?
I wiggle everything possibly related to headlights no flicker at all
is it usualy something internal with headlight?
I'm gonna swap the bulbs and see whats up
I'm also getting the AFS system error. lately its been intermittently popping up and disappearing again every few days
Old Oct 11, 2017 | 03:13 PM
fuzzysig's Avatar
whats the most common cause of the afs light and flicker?
I checked everything already and cant find sht lol
Old Oct 11, 2017 | 05:45 PM
How's your AFS sensor?
