Bluetooth amp
Old May 6, 2015 | 11:27 AM
HEAVY_RL's Avatar
Bluetooth amp
who wants to be the first to try this out?
RE Audio BT900.4 4-Chan Class AB Bluetooth Car Amplifier (BT9004)
Bluetooth Sound without the Headunit
Have you ever wanted to add Bluetooth functionality to your car without opening up your dash and installing a costly new headunit? The new RE Audio BT900.4 Bluetooth amplifier allows you to do just that. This innovative 4-channel 480 watt RMS amp has integrated Bluetooth so you can stream your favorite music straight to your sound system, no headunit required. The Bluetooth has outstanding range, allowing you to stream your music from across a parking lot if you ever want to show off. An RCA input also allows the BT900.4 to be used as a traditional amplifier with your headunit. With on-board overload, short circuit, over heat and under voltage system protection, this amp will be a perfect, long term addition to your sound system. Being unable or unwilling to install a new headunit in your car is no longer an excuse to not have Bluetooth!
Old May 7, 2015 | 01:57 PM
titomang's Avatar
Originally Posted by HEAVY_RL
Hmmm...looks interesting. I might have to give this a try....
as soon as Heavy confirms it works great with our RL.
On a serious note, not many reviews out there on this product. I guess since it's newer technology. Definitely interesting though.
Old May 7, 2015 | 02:32 PM
oo7spy's Avatar
So you don't have to open your dash, just your trunk liner? Also, 4 channels won't cut it in the RL. (Or almost any modern car.)
Old May 8, 2015 | 06:49 AM
HEAVY_RL's Avatar
How many channels would you like good sir?
I wont be trying it as my USAspec does just fine.
I did think about using it on my ATV.
Old May 8, 2015 | 10:44 AM
oo7spy's Avatar
Well, given that the RL is 5.1, you kind of need 6 channels. But that still doesn't cover the front tweeters or the rear deck.
Old May 8, 2015 | 01:44 PM
HEAVY_RL's Avatar
I see... I didnt consider all that 5.1 jazz.
Old May 10, 2015 | 09:05 PM
Carbon Legend's Avatar
front tweeters are connected to the front door midbass. No pinout on the amp for front tweeters. There is a output for the rear tweeters on the rear deck.
Driver Front
Pass Front
Driver Back door
Pass Back door
Driver rear deck
Pass Rear Deck
Sub
Front Center Channel
Jul 16, 2017 07:33 AM
MetalGearTypeS
Aug 29, 2016 08:28 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
SUPRMN84
Oct 7, 2015 09:46 PM
