Bad door Handle
Bad door Handle
I replaced my battery yesterday and washed my car too. Everything was fine all night and this morning as I drove to work. At noon today I went to my car to grab some lunch and I ran into some problems. None of the courtesy lights came on and the locks didnt work. I started it up with the actual key and the alarm goes off.
While reading up on this I saw that a member's (RaskyR1) wife "reinitialized" the key so that the car would start without the alarm going off in this old thread.
https://acurazine.com/forums/showthr...ighlight=alarm
1. Is the reintialization possible or must I pull the alarm/horn fuse so that I can make it home?
2. How do I narrow down which handle is bad so that I can replace it myself?
The battery reset didnt do anything. I decided to drive in the current state until I get the parts to fix it myself. For anyone who decides to drive the car in this state and fix it on your own you will face the following.
- You will need to remove the fuse for the horn.
- You will need a screwdriver to release into gear.
- The radio will work once the code is entered.
- The nav wont work.
- The auto locks wont work.
- Once you start the car your lights will flash for a while. (Just leave them on and they wont flash )
- You will need to use the lever in the trunk to open the fuel door.
Slight update
So I took a shot and bought a passenger side door handle (60 bux) and my situation didnt change. After some thought I decided to figure out which handle it was. This is what I did.
I disconnected the RH door handle and replaced the #7 10 amp fuse. The fuse blew again so I reconnected the RH door handle, disconnceted the LH door handle and replaced the #7 10 amp fuse. This time it didnt blow so knew it was the LH door handle giving me the issues. Save yourself some time and money with a bit of trouble shooting.
Also with the troublesome handle disconnected, all of your amenities will work as they should (nav,bluetooth,courtesy lights n etc.). However, if you dont replace the fuse for the horn you will still have the following:
- VSA light
- SH-AWD error
- You will still need a screw driver to release the parking break into gear.
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
Sep 17, 2015 09:01 PM
