BAD BAD Day, Speaker Issues
Old Feb 4, 2014 | 01:46 PM
mrm143's Avatar
2007 RL
SO.... where do we start, Yesterday in the snow over here in New England, I went through a HUGE pothole, and busted a tire...FANTASTIC... Out in the snow, freezing, put on the spare...
Drove to the tire place, had 2 new tires put on... FANTASTIC...
Then, I start noticing that I have no sound in the car..
EVERYTHING works, NAVI, Radio, Bluetooth, but Absolutely NO SOUND....
I searched the forums, and tried everything mentioned... I checked the 30amp on the passenger side kick well, check the radio fuse, pulled radio fuse, reset radio, went into radio daigs ( 1 6 and power) says amp OK
Went into the trunk, trying to find the amp, not sure where it is LOL, I saw something near the fuel pump access door, not sure what it was, made sure all wires were tight....
so, HELP ME lol
Could the bump from the pothole have knocked something loose, it was the front right tire.... and WHERE is the amp? Is it just a coincidence this happened at the same time as the bump??
Old Feb 4, 2014 | 02:45 PM
mrm143's Avatar
PS... I was looking at pics of the amp on ebay, and I don't think what I found was the amp
Old Feb 4, 2014 | 02:57 PM
EL19's Avatar
What you found isn't the amp. The amp is on the opposite side of the trunk (passenger side).
When I first purchased my car, the guy who had it before me fried the radio by leaving the aftermarket amp remote wire bare in the trunk which shorted out the stock headunit. Acura had to fix it somehow. However, if I go over a large enough bump like the one you've described the radio will go out. I have to smack the side of the radio to get it to come on again. Thankfully 2+ years later I've had no issues.
You may have a similar issue, maybe the bump caused the probelm with the headunit or the amp, or it could all be coincidence.
Old Feb 4, 2014 | 03:01 PM
mrm143's Avatar
The box I found was on the passenger side (opposite the dvd drive)
Ill give her a few whacks... But still trying to find the amp LOL
Old Feb 4, 2014 | 03:50 PM
mrm143's Avatar
Found the amp, it was on the passenger SIDE like above the wheel well...
Everything looks connected...
Banged the crap outta the radio, and nothing
Old Feb 4, 2014 | 04:30 PM
HEAVY_RL's Avatar
well, my first thought is to make sure you have a signal into the amp.
if not you have an output issue at the radio.
Old Feb 5, 2014 | 09:32 AM
mrm143's Avatar
well.... I got in the car this morning, and now it's working.....
LOL
Old Feb 5, 2014 | 10:39 AM
HEAVY_RL's Avatar
so, it was a loose connection that either put the system in fault or that "fell" back in place.
Old Feb 5, 2014 | 11:57 AM
oo7spy's Avatar
Here is your amp.
Old Feb 20, 2014 | 12:02 PM
mrm143's Avatar
So here is an update.... It was on one day, off the next day, etc...
I pulled the rug in the trunk, and noticed that water is coming in right ABOVE the amp, starting to actually cause it to discolor..... SO their is my issue, now I need to know where that water may be coming from?
any ideas??
Its actually coming in from the seam in the metal right ABOVE the amp in the pic that was posted above.....
Old Feb 20, 2014 | 12:57 PM
mrm143's Avatar
any ideas??
Looks like it is coming in where the trunk support hole is... going to put down some liquid rubber and reseal it...
mada51589
Jan 9, 2025 04:40 PM
AndrewS
19
Mar 14, 2024 06:59 PM
sockr1
Oct 1, 2015 01:31 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
iRaw
ILX
Sep 5, 2015 12:10 AM
