Backup Camera DIY help please
Old Nov 16, 2008 | 05:06 AM
nyctl's Avatar
05 RL
Bought Dom's unit yesterday and picked up an audiovox camera at circuit city for $65 (hoorah for 155 store closing)
I've been at this since 10:30 pm last night with no breaks.
Took trunk apart, installed the camera and unit and only thing left is wiring issues
I need help identifying where to tap into to give the unit its 12V
I need help identifying which wire is the reverse light. I was able to isolate a plug on the left that controls the reverse light and the brake light but I don't know which one of the 5 is for the reverse light.
Lastly I need help in figuring out which wire to tap on the trunk lid to give the camera its 12V
I need sleep so thanks in advance
Oh and I'm getting a msg saying DRL off
Any ideas why that will happen all of a sudden?
Thanks again
Sleep is calling.
Old Nov 16, 2008 | 12:03 PM
nyctl's Avatar
24 views and no suggestions?
Old Nov 16, 2008 | 05:42 PM
drolds72's Avatar
Since the nav unit and screen is on in Acc I, I tapped power for the interface from the purple wire on the big harness that originally plugged into back of Nav unit. It is a small diameter wire, but I was able to use a T-tap with no problem. Just peel back the harness cover a few inches.
Power for the camera and the trigger wire comes from the reverse lead. The factory manual says it should be brown, but it was not on my harness. I just pulled the d/s assembly out and used a meter to verify the hot reverse lead, and used a t-tap there as well. There is a ground post in close proximity there as well.
Old Nov 16, 2008 | 06:08 PM
dwboston's Avatar
The "DRL Off" message usually comes on when the parking brake is set.
Old Nov 16, 2008 | 11:13 PM
nyctl's Avatar
dude thanks a bunch!!!!!!!!!!!!!!
i literally went to walmart and bought 2 12V batteries to tape to the camera and unit until i could figure it out. Then I thought better and ended up disconnecting the camera and the unit and putting the trunk back together. i'll try your suggestions this week.
thanks. i figured that one out by searching the quirks thread but it was too late to edit it out of the OP.
Old Nov 23, 2008 | 07:31 PM
nyctl's Avatar
mission accomplished
thanks to drolds for the help!
all that is left is for me to run a fuse connector between the 12 v power supply and the units power wire.
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
