Aftermarket amp and subwoofer help
Old Jul 23, 2016 | 09:23 PM
Gmoney83's Avatar
3rd Gear
Hello all, I have an 05 RL SH and I recently installed an aftermarket sub and amp. I installed a JL audio 10w7 and a JL audio 500/1 mono sub amp. (I can supply power wire routing pics if anyone wants them). I am a master cerified technician so no need for dumbing down technical responses. The issue I am having is that intermittently at start up I am sometimes getting feed back through the sub. It's a brief 5-10 second period where the sub buzzes (not a poor ground issue). After that all is well. I ran the the rca feed to the JL amp from the post amp wiring from the Bose amp. Not sure if the issue is a self test upon startup or something else all together. Thinking about trying to run rca feed pre amp to see if this corrects it. Just curious if anyone else has run into this issue. Any feedback would be greatly appreciated.
Old Jul 24, 2016 | 05:34 AM
NathanJax's Avatar
Did you disconnect the ANC?
Old Jul 24, 2016 | 09:32 AM
Gmoney83's Avatar
3rd Gear
Yeah I shut it down through the diagnostic settings, still getting an initial low hum from sub.
Old Jul 24, 2016 | 09:46 AM
oo7spy's Avatar
That menu setting is not sticky. You will have to set it each time you start the engine. You can either disconnect the microphones or you can disconnect the ANC harness at the Bose amp in the passenger quarter panel.
Old Jul 24, 2016 | 10:56 AM
Gmoney83's Avatar
3rd Gear
Saw one of your other posts about in in another part of the forum 007spy, I pulled down the rear dome light and unplugged the microphone. Sounds great now. Thanks so much. You are a big help to this community.
Old Feb 16, 2017 | 11:29 AM
Mwilkins1973's Avatar
4th Gear
would love to see where you run your power wires
Old Feb 17, 2017 | 06:54 AM
projektvertx's Avatar
For the amp? There is a hole in the firewall you can bring it thru...
enzyme
Jul 21, 2016 06:16 PM
Andrewsaintf
Jul 13, 2016 01:08 PM
chillingrsx
ILX Performance Parts & Modifications
15
Jun 12, 2016 10:48 AM
ebernedo86
Mar 3, 2016 02:56 PM
bgymr
Feb 10, 2016 12:20 AM
