Aftermarket amp and subwoofer help
Old 07-23-2016, 09:23 PM
3rd Gear
Gmoney83's Avatar
Hello all, I have an 05 RL SH and I recently installed an aftermarket sub and amp. I installed a JL audio 10w7 and a JL audio 500/1 mono sub amp. (I can supply power wire routing pics if anyone wants them). I am a master cerified technician so no need for dumbing down technical responses. The issue I am having is that intermittently at start up I am sometimes getting feed back through the sub. It's a brief 5-10 second period where the sub buzzes (not a poor ground issue). After that all is well. I ran the the rca feed to the JL amp from the post amp wiring from the Bose amp. Not sure if the issue is a self test upon startup or something else all together. Thinking about trying to run rca feed pre amp to see if this corrects it. Just curious if anyone else has run into this issue. Any feedback would be greatly appreciated.
Old 07-24-2016, 05:34 AM
NathanJax's Avatar
Did you disconnect the ANC?
Gmoney83 (07-24-2016)
Old 07-24-2016, 09:32 AM
3rd Gear
Gmoney83's Avatar
Yeah I shut it down through the diagnostic settings, still getting an initial low hum from sub.
Old 07-24-2016, 09:46 AM
oo7spy's Avatar
Received 7,247 Likes on 4,858 Posts
That menu setting is not sticky. You will have to set it each time you start the engine. You can either disconnect the microphones or you can disconnect the ANC harness at the Bose amp in the passenger quarter panel.
Old 07-24-2016, 10:56 AM
3rd Gear
Gmoney83's Avatar
Saw one of your other posts about in in another part of the forum 007spy, I pulled down the rear dome light and unplugged the microphone. Sounds great now. Thanks so much. You are a big help to this community.
Old 02-16-2017, 11:29 AM
4th Gear
Mwilkins1973's Avatar
would love to see where you run your power wires
Old 02-17-2017, 06:54 AM
projektvertx's Avatar
For the amp? There is a hole in the firewall you can bring it thru...
enzyme
07-21-2016 06:16 PM
Andrewsaintf
07-13-2016 01:08 PM
chillingrsx
ILX Performance Parts & Modifications
15
06-12-2016 10:48 AM
ebernedo86
03-03-2016 02:56 PM
bgymr
02-10-2016 12:20 AM
Quick Reply: Aftermarket amp and subwoofer help
