AcuraLink & T-Mobile
I cannot connect to T-Mobile using AcuraLink. I have tried the default connection string *99# and I have also changed it to *99***# (As suggested by one of the postings). Neither of the two connection strings work for me. PLEASE HELP!!!!
The *99# is for AT&T. Not sure what the other string is for. If you go into easy set \up and choose AT&T you will see the *99# is for AT&T. However, mine does not work and I am on AT&T. What type of phone do you have? I have the Audiovox SMT 5600.
...just another stooge...
Originally Posted by adaie
I have a Sony Ericsson V802. All my blootooth settings work correctly. I just cant get the damn AcuraLink working.
I guess T-Mobile has the same settings as AT&T.
I think we have lots of company.
I had the same problem with Verizon when I purchased a V710. In fact, I didn't have the option for Verizon in the AcuraLink setup and I suspect it is because Verizon had no bluetooth during development. I never replaced the phone with another bluetooth yet, I am comtemplating getting service elsewhere but my wife and I talk a lot during the day and she doesn't want to switch (A bad experience in customer service with ATT). The free mobile to mobile is the only reason I haven't switched. I did speak to a guy who is testing the Palm Treo 650 for Verizon and he said that the testing is ahead of schedule and the estimated release is in August. Thats doesn't help my cause since I may not even be alive in August. I need a fix now and may turn my service plan down annd forward my number to my new phone to satisfy my wife.
I do have the data plan. I contacted t-mobile and they told me I need to purchase their internet plan which is $29.99 a month!!! This plan includes access to t-mobile GPRS. Otherwise I have to use another ISP to connect to acuralink.
I'm temporarily on T-Mobile and having the same issue with my 7100t Crackberry. I was using the "classic" (awkward, bulky) shaped 7250 Crackberry on Cingular with no problems. The 7100t works in all respects except for Acuralink. This is a corporate-supplied device and it has every imagineable service enabled. In another week or so I'll be getting swapped out to a 7100g (Cingular) and I'm hoping I'll be back in a state of one-ness with Acuralink. Pretty frustrating, though.
Originally Posted by larryka
You shouldn't need their "T-Mobile Internet" plan, even if you did it should only be $19.99 to add it to a voice plan, not $29.99. Last time I checked, my RL was able to connect to AcuraLink via my SE T-610 on T-Mobile with the $4.99 T-Zones plan. I haven't been in the car for three weeks, so maybe something changed. I'll try it this sometime today.
When I first got my RL I remember a screen coming up to activate Acuralink. I have my cell phones with Verizon and this was not one of the providers shown on the screen. I have not tried anymore to set this up since then.
My Motorola V710 did link with the HFL with no problem.
Originally Posted by AcuraRLBlue
Larryka: Have you had a chance to confirm your SE T-610 connection to AcuraLink? Thanks.
I had a chance to try my T-610 on T-Mobile in my RL yesterday, and it worked fine using the T-Mobile quick setup option. FWIW, I used to have the $19.99 Internet data plan, but I went down to the $4.99 T-Zones plan a couple of months ago.
I also have a T-mobile T-zone $4.99 plan and using SE W800i phone, but could not connect to AcuraLink.
Larryka-how did you connect to AcuraLink? I tried using the easy setup but to no avail. Any help would be appreciated. Thanks.
I have a SonyErricsson k700i on t-mobile with the GPRS data plan, and I can't connect to Acuralink, either.
tmobile offers no support for this, they say call Acura. Acura offers no support for this, they say call tmobile.
My dealer's service manager said "This feature isn't enabled yet, it's not supposed to work." Yet, of course, it works for other people, and when I had a Sprint Samsung A900 for a week, it worked flawlessly on the default Sprint settings.... of course, the phone wouldn't hang up when you pressed disconnect, but that's another matter entirely.
*shrug*
*shrug*
I noticed that using the acuralink settings (under easy setup) for the cingular formally ATT phone on my tmobile phone, it actually put the phone in GPRS mode (which is more than any of the other presets did). I dont have the gprs data package but that may work on some plans?
Just an update.. Using a razr and tmobile (no data plan) I was able to connect to acuralink by using a isp modem dialup #. This was done via the custom setup menu item and entering the isp's phone # under phone # (where it previously had *99# I think). The razr dials up and acts like a modem. I also had to supply the userid and password via the appropriate menu options. Worked great.
rollinm - Care to tell us the isp number that you used? And also, how do you get the userid and password? Do you have to register somewhere first to get the id and password? Thanks in advance.
I have free dialup access via my broadband provider (earthlink). So you might check to see if your current internet proivder also provides dial up access with your service.
Alternative, you might also try http://www.freecenter.com/dialup.html. I believe I saw some of these free dialup isps referenced in a verizon thread here on acurazine. They may not have local #'s, with tmobile you may get free long distance calls so free still?
summary of the root causes of problems in this thread
Hi.
Here's why some of your phones in this thread are working for Acura Link and some are not.
1. THE FUNDAMENTAL REQUIREMENT. Of course, the phone needs to have Bluetooth and be compatible with the Acura Handsfreelink. You can find officially compatible phones at: http://www.handsfreelink.com. Note: of course there are other BT phones that will work with the system, they just haven't been officially endorsed for any number of reasons I won't get into.
2. THE PHONE MUST SUPPORT BLUETOOTH DUN (DialUp Networking Profile). Many if not most phones have had it disabled by the carriers. MOST phones as designed include DUN but it is turned off by carrier or phone man'f for any number of reasons. To determine whether your phone will support, again, go to http://www.handsfreelink.com. The phones that will NOT work with Acura Link are shown as "Does not support offboard diagnosis". Similar note: this does not mean that some other BT phones are available that do support DUN, and will somehow work, it just means that for one or more reasons they are not supported.
3. (IF YOUR PHONE IS COMPATIBLE) YOU MAY NEED TO HAVE A DATA PLAN. Depends upon the carrier. Call their customer service and ASK. Ask to talk specifically to a DATA SUPPORT person, if they have such. Today, most customers will be able to access data, it will just cost more if you don't opt for an economical package (pay per kilobyte as opposed to "all you can eat" type plans). To test whether you can use data connectivity on your phone or not (note: I do not mean data connectivity by Bluetooth DUN here. that's another story altogether), open the phone's mobile browser (assuming it has one ... Verizon is strange on this matter) and see if you can connect to mobile internet stuff. If not, you likely don't have data or aren't set up correctly. Again, consult your carrier's support line, preferably data support.
4. (IF YOU KNOW YOU HAVE A DATA PLAN) You need to have the right settings to connect. First try the preset options for Acura Link connection in the car. If that doesn't work, consult the carrier, as in point #3. There are also a number of other places you can find the connection settings on the Internet but it's a complicated issue.
5. IN ALL CASES, complain to your carrier about the lack of usability and carrier accountability regarding data features. It's unacceptable.
and now, regarding specifics... (Acuralink support)
And now, regarding various specifics from your previous posts perhaps not covered by my previous post:
Bluetooth dialup networking (DUN) and data access via a cell phone versus ISP-type dialup are not really related. The topics don't mix very well. The dial strings like *99# are not general 'ISP' numbers. They are strings that do something in the context of YOUR wireless carrier's specific system configuration. They sometimes ARE the same across different carriers. But this is because the switches and equipment are similar. You just have to check with your carrier's support team, preferably data or "mobile internet" support, if available.
Your dealer is full of it (seems to be the prevailing case). Acura Care SHOULD have referred you to Handsfreelink support (in addition to web there is also a help line). K700i is officially supported. It should work. Check the software version shown on the Acura Handsfreelink site against what you have. For Sony Ericsson phones, there is one helpful resource in particular on Sony Ericsson's site that will send down the carrier connection settings to your phone via SMS: http://www.sonyericsson.com/spg.jsp?...s1_1&pid=10179. The neat trick is if you select a Sony Ericsson phone that is available through your carrier, this "WAP configurator" tool will send the SMS to any phone, regardless of manufacturer and the data settings should be the same. However, I have to state the inevitable caveat that the settings they send may be WAP-specific settings and may not work for the Acura Link use case. Sometimes GPRS settings are needed, sometimes EDGE, and so on and so forth depending upon your phone's capabilities (GPRS, EDGE, etc), maybe your data plan and account and other factors. A lot of times you'll get lucky, though, and at least those settings will work for a basic connection. This is the beauty of the utterly confusing and unusable world of carrier data connectivity. Add Bluetooth DUN and interoperability between devices on top of this and it's a wonder it all works at all, ever.
SE W800i is, in general, NOT officially supported by Handsfreelink. That doesn't mean it absolutely won't work. In fact, it sounds as if you use it for handsfree call functions already.
Good to hear. This is expected. RAZR (Cingular or T-Mobile NOT Verizon RAZR V3c) is a good phone for use with Acuralink. Watch your data charges closely, though, since you have opted no data plan.
-AND-
Motorola Verizon V710 is supported for HFL handsfree functions but not Acura Link (aka "offboard diagnosis") functions. And HFL support with V710 is only with software version 1.40 or later.
Verizon, in general, has disabled Bluetooth DUN in their handsets (don't get it confused with general DUN or "tethered DUN" [using the phone as a modem using a cable] which may well be supported but obviously does you no good in this case). Some of the smartphones that can be put on PDA plan (unlimited PDA data) do have BT DUN enabled, but HFL and the device have interoperability issues. XV6600 is one particular example of this. I use its BT DUN capability for other purposes but it does not work well at all for HFL and Acura Link.
In parallel to obtaining yourself a phone that's on the compatible list, suggest petitioning Verizon for Bluetooth DUN support and easy, straightforward data connection options if you think it's important (as obviously I do).
V802 is not supported for HFL in general. Good to hear that it works for you at least for basic HFL functionality. See handsfreelink for further info.
Blackberry Cingular 7100g is supported for general HFL functions, but NOT Acuralink.
HOPE THIS HELPED EVERYONE A BIT!!!!
I have a Sony Ericsson V802. All my Bluetooth settings work correctly. I just cant get the damn AcuraLink working.
Motorola Razor
I was able to connect to the server with my Razor using T-Mobile internet service. It may seem stupid but I don't know what are really the benefits of it. Could anyone help me?
Well, right now, the only services available are diagnostics. So in other words, only if you have a problem ... the car can contact Acura and get further information on your problem.
Just visited the dealer for an oil change and my primary purpose is to check the "unable to link" message with my AcuraLink. The dealer's tech guy know nothing and suggested me to call Acura. $*%$#
I have black berry and moto razr both with internet service (T-Mobile) but was never able to connect. The guy did say that it's all VIN based and you will get a letter if there is any issue with your particular vehicle. And as far as he knows there has been no tech calls for RL in the past year. Good luck everyone.
Originally Posted by jfprl
What was the process? Where did you insert *99#?
In other words, if you can use the phone as a GPRS modem with your laptop, you should be able to use that dialing string to connect through it.
On the Acura, just use the connection settings for AT&T Mmode -- which is just to dial *99#. It should already be set up in the phone. If you have a working GPRS internet connection from Tmobile already set up on a compatible GSM phone, it should work.
You may need to subscribe to T-Mobile's VPN service. I am a VPN subscriber, I don't use the normal T-Zones internet connection, and I have the $29 unlimited data pacakge, which lets me use my phone as a modem over the t-mobile network with my laptop. That may be why my phone works and most don't.
Barb Jackson
09-15-2015 02:27 PM
F900
Console & Computer Gaming
01-12-2005 05:36 PM
