Acu-15xl install
Old Mar 28, 2010 | 02:15 PM
drolds72's Avatar
Acu-15xl install
I just installed mine. Works great. Noticed a few questions about how to run the cable, and this is how I did it.
Once I fed the cable to the area by the pass through in the trunk, I removed the rear seat bottom. There is just enough space under the pass thru to feed the cable through. Then, I removed the plastic sill moulding, and the pillar moulding to access the edge of the carpet. fed the cable along the edge, where you will see some other harnesses. There is a hole already in the carpet under the driver seat. Going from the edge to that hole was by far the most challenging part. You will need to rig up some sort of fishtape. That is where i brought the cable through and plugged it into the interface. Then a couple of wireties from the cable to an existing harness keeps it solid and out of sight when the seat is back. It winds up right next to the underseat vent. I just then pulled the ipod connector plug around the seat belt stub and left it out like that. I am ok with it, and I did not see a real easy way to get it into the lower console compartment without drilling a hole in the inside compartment. Hope this helps someone!
Old Apr 4, 2010 | 10:00 PM
SnoWRL's Avatar
where can I get this thing and is there any pics of people using it cause I would like to see its interface. I definetly need an Ipod connector where I can control the ipod through my radio interface. Help me out guys
Old Apr 5, 2010 | 03:23 PM
drolds72's Avatar
Here you go:
http://www.usaspec.com/product.php?ProductID=56
can find on net for under $150...
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
