wiper arms
Old Dec 9, 2008 | 06:46 PM
dubz ASPEC's Avatar
wiper arms
is there a way to adjust the wiper blade arms so they are directly over the defrost vent on the windshield?
Old Dec 9, 2008 | 06:48 PM
connolley's Avatar
I just know that you pull them up for the winter so they don't get frozen, the push them back down in the spring.
Old Dec 9, 2008 | 07:01 PM
dubz ASPEC's Avatar
yes i remember reading that somewhere, problem is i can't get them up over the defrost vent and they are full of ice right now!
Old Dec 9, 2008 | 10:27 PM
dubz ASPEC's Avatar
nevermind i got it...
Old Dec 10, 2008 | 07:18 PM
death's Avatar
You could also get winter wipers. This is what I had when I lived up in NH.
They actually work quite well.
Old Dec 10, 2008 | 07:43 PM
lland's Avatar
How did you get the winter blades on your RL? It doesn't have "standard" blade mounts.
LL
Old Dec 10, 2008 | 07:51 PM
death's Avatar
LL
Good question... I didn't realize the RL has special blade mounts. There has to be at least one company out there that makes winter wipers which fit the RL.
Are you saying that every member on this board can only get new wipers from a dealer? Buying wipers from dealer = epic fail
Old Dec 10, 2008 | 08:55 PM
lland's Avatar
As far as I know, the blades have to be purchased from Acura but many refills will fit the blades already on the car (I've been using PIAA Super Silicone refills) but I'm not aware of any winter blades. I don't belive you can get winter refills as the rubber completely surrounds the blade.
LL
Old Dec 11, 2008 | 09:55 AM
CFoote's Avatar
Winter blades are good, but they streak and chatter on the highway due to the wind. I don't know whether the RL can or cannot take winter blades, I've never replaced the wipers yet.
Chris
Old Dec 11, 2008 | 11:24 AM
Ballinger's Avatar
How do you get the inserts out of the Acura arms? Is this a stupid question? I sure felt stupid when I tried this.
Old Dec 11, 2008 | 11:27 AM
death's Avatar
Can someone post pictures of what the RL wiper bracket looks like? I'm curious what they actually look like.
Old Dec 11, 2008 | 02:23 PM
lland's Avatar
They slide out like any other. I took my blades off the arms (2 screws each) just to make it a bit easier.
LL
Old Dec 11, 2008 | 05:48 PM
neuronbob's Avatar
Um.....it's in the manual.
Originally Posted by 2006 RL manual, page 381-2
1.Adjust the windshield wiper arms to the winter position by holding both wiper arms as shown in the illustration at the same time (see page 135). Raise the wiper arms off the windshield.
2. Push the edge of the cover on the blade assembly until the other side of edge is pivoted out, and remove the cover.
3. Disconnect the blade assembly from the wiper arm by removing
the two screws from the arm.
4. Remove the blade f rom its holder by grasping the tabbed end of the blade. Pull firmly until the tabs come out of the holder.
5. Examine the new wiper blades. If they have no plastic or metal reinforcement along the back edge, remove the metal reinforcement strips from the old wiper blade, and install them in the slots along the edge of the new blade.
6. Slide the new wiper blade into the holder until the tabs lock.
7. Reinstall the blade assembly to the wiper arm and tighten the two screws securely. Reinstall the cover by pushing in.
8. Set the wiper arms back on the windshield. Adjust the windshield wipers to their previously parked position.
Old Jan 3, 2009 | 10:34 AM
kjglasch's Avatar
I tried ANCO Contour for WInter - No Luck
It is frustrating when you go to Auto Zone and Anco Countour blades have a listing for my 05 RL. The blades look sweet and would be great for this crappy, icy MPLS winter.
No way I could get the blade to mount. Who has the aftermarket company that sells blades that mount to the two screw mechanism?
Any help is appreciated.
mlody
Dec 4, 2019 02:11 PM
Jul 16, 2017 07:33 AM
adreano17
Sep 29, 2015 08:48 AM
Brandle34
Sep 23, 2015 07:20 PM
