When I reseal the oil pump, should I remove timing belt?
My Honda Legend(Acura RL 2th gen) has an oil leak issue.
I try to reseal the oil pump and replace the gasket of it.
Should I remove timing belt to access the oil pump?
2 months ago, I went to the dealership and timing belt and water pump etc. were replaced.
So I don't want to remove timing belt again, but if I have to do, I will do...
Could you give some advices?
Thank you for your help in advance.
Yes, you definitely need to disassemble the entire timing mechanism and remove the oil pan for this job. Only 6-7 hours of labor
5point9Limited
1G TL (1996-1998)
19
09-30-2008 01:06 PM
