wheels tires
Old Mar 21, 2014 | 10:58 PM
RL-SK8's Avatar
Question wheels tires
hi please help me to find right offset for RL 2008
R18 offset ???
R19 offset ???
this is for summer tires. I don't have summer tires also any ideas????
i think for summer i can have wider tires. For now I have 17x8 +55 offset
And how wide i can go.
Thanks!!!!!
Old Mar 21, 2014 | 11:02 PM
oo7spy's Avatar
Every wheel is different. Offset has no relation to clearing the caliper; it only relates to the fender. It's an impossible question to answer from numbers alone.
Old Mar 21, 2014 | 11:11 PM
BDoggPrelude's Avatar
Old Mar 21, 2014 | 11:12 PM
RL-SK8's Avatar
So how I can find right one?
Old Mar 21, 2014 | 11:34 PM
RL-SK8's Avatar
Offset: 40mm
Backspacing: 6.062"
Bolt Pattern: 5-120
Rec. Tire Size: 245/45-18
Weight: 25.15lbs.
Finish: Black Painted
Construction: 1pc. Low Pressure Cast
That will fit?????
Old Mar 22, 2014 | 04:33 AM
ChocBoyWonder's Avatar
It depends on the wheel. The specs sound like they will work. One thing you need to make sure of is that the wheel fits over the front brakes.
Old Mar 22, 2014 | 09:47 AM
oo7spy's Avatar
Here's how I tell if something fits. I try it on.
Old Mar 22, 2014 | 11:41 AM
What's the wheel? Where did you get those specs from?
They look like TireRack's product specs to me, as far as the verbage. If so, and if you found them through their online fitment guide, they should fit. TireRack's fitment guide is pretty spot on.
Old Mar 22, 2014 | 01:24 PM
RL-SK8's Avatar
Yes it is from tire rack`s
And front brake original acura not after market
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
KB1_EJ6
Nov 13, 2016 09:51 PM
lland
Oct 4, 2015 04:47 PM
merc009
Oct 3, 2015 12:59 AM
