What could be wrong?
Old Mar 28, 2011 | 12:22 PM
synth19's Avatar
Symptoms:
Driving the car ('05 RL) and then suddenly, power completely shuts off for a second or two, and then comes back. Warnings that pop op include check emissions and also the power steering warning. This happened a few times since Saturday. I don't think this has to do with the battery. Car starts up fine, and even was stored for 2 weeks while on vacation and immediate start-up. Bringing the car to the dealership on Wednesday. I just hope the power cut doesn't happen again in the interim.
Old Mar 28, 2011 | 12:32 PM
EL19's Avatar
Possibly the alternator
Old Mar 28, 2011 | 12:34 PM
synth19's Avatar
yes, my initial thoughts as well....
Old Mar 28, 2011 | 12:39 PM
EL19's Avatar
Reason I say this is because this just happened to my 05. Only difference is the SH-AWD warning came on with the check charging system wanrning. Then it wouldnt start back up. Got it towed to Acura and they stated Aletrnator gave no readings. Hopefully yours gets resolved
Old Mar 28, 2011 | 02:07 PM
GoHawks's Avatar
2012 Cadillac CTS-V Coupe
I doubt it's the alternator if it continues to run.
The car will run off the charge from the alternator. Once you start a car, you can remove the battery and the car will continue to run as it's drawing the power it needs from the alternator. You just can't start it again unless you re-install the battery.
Typically if the alternator isn't charging the car will draw it's power from the battery and when the battery is dead, the car will stall as it can no longer run it's systems (i.e. spark, fuel pump and fuel inection).
If the car is cutting out and then comes back I wonder if it has to do with the main circuit. There may be a short that is occuring that it interrupting power and it's causing the trouble codes.
A power interruption while moving will cause the power steering light to come on. I've done that where while in motion (don't remember the reason why I did it), I would put the car in neutral, quickly turn the car off and then restart it. Since it's in neutral you can't completely turn the knob off but the restart causes a power interruption. Once it restarted the power steering idiot light would go on. It would only turn off after I stopped the car, put it in park and completely turn the car off and restart it.
Old Mar 28, 2011 | 02:50 PM
sqranks's Avatar
Did you store your car where rodents etc. were? Maybe some critters got to your wires??? Just a a thought..
Old Mar 28, 2011 | 03:07 PM
Zelaya's Avatar
2012 TL SH-AWD
You just got the car and already having issues? Hope it doesn't get worse.
In regards to OP I hope you resolve your issues. What I've seen from my end when I park my RL for days without starting the car hesitate on the pick up and once the car gets warm no problem.
Old Mar 28, 2011 | 06:38 PM
rtr's Avatar
rtr
RL owner
Is it a CPO car?
Old Mar 28, 2011 | 07:03 PM
VQPower37's Avatar
^ i hope it is ... electrical problems could cost u and arm and a leg
Old Mar 29, 2011 | 08:57 AM
Blazing GT's Avatar
that happened to me before...
i was driving in the rain and the car lost power where everything locked up. It was a very scary situation. This nightmare lasted 2 seconds tops. I pulled over and checked the battery and the negative terminal was loose.
Old Mar 29, 2011 | 10:09 AM
rtr's Avatar
rtr
RL owner
yea i had to tighten mine when i bought it
Old Mar 29, 2011 | 11:53 AM
oo7spy's Avatar
I had the loose cable terminal issue on Legend #1, except on the positive terminal. I didn't lose complete power, but all of the electronics (radio, radar, ect.) would reset sporadically when I was driving. Tightening fixed it right up.
Old Mar 29, 2011 | 01:38 PM
wackjum's Avatar
Did it match the symptoms like I had? (Thread here: https://acurazine.com/forums/2g-rl-2005-2012-76/random-power-outages-792450/)
If so, loose terminal. Even though Acura checked the battery and said it was fine........
Old Mar 29, 2011 | 05:38 PM
synth19's Avatar
Nope. No rodents.
Originally Posted by rtr
Is it a CPO car?
Not CPO, but I have a 100k extended warranty I purchased from Acura. Because of all the electronic goodies, I decided to get an extended warranty (Thank God)!
Originally Posted by wackjum
Did it match the symptoms like I had? (Thread here: https://acurazine.com/forums/showthread.php?t=792450)
Nope, not the terminals. I tightened a bit anyways just to make sure. Issue seemed to resolve today, so I canceled my appointment at the dealer and thought I'd give it another week. However, this afternoon the first set of sympotms started again- Radio cuts on and off....almost as if the volume goes down and back to set volume, and so on. I'll see what happens and reschedule the appointment if issue persists.
Old Mar 30, 2011 | 09:30 AM
rtr's Avatar
rtr
RL owner
It should be fine. Check to make sure your battery is not sliding around the dealers never check so do it your self
Old May 4, 2011 | 10:20 AM
synth19's Avatar
OK guys, just an update.... issue was due to some corrosion around the battery terminals. It didn't look too bad, so never thought this was the issue. But after removing the battery and further inspection, looked like a through cleaning wouldn't hurt. After cleaning them up well, seems to have eliminated the issue.
Old May 4, 2011 | 11:37 AM
HEAVY_RL's Avatar
its amazing how simple battery issues (even when the car starts fine) can wreak havoc on these cars.
Old May 4, 2011 | 01:27 PM
tnobori1's Avatar
Missing my
I recommend these for a cheap preventive measure.
http://www.amazon.com/gp/aw/d/B000NI...728357-0716827
Old May 6, 2011 | 08:33 AM
rtr's Avatar
rtr
RL owner
Good job! I had a feeling the dealer never check properly
acuratl26
Apr 23, 2020 07:30 PM
ttimberlak443
21
Oct 22, 2016 10:23 PM
BrownBuck
NY/NJ
Sep 29, 2015 09:53 PM
rangomango
California
Sep 24, 2015 05:47 PM
Hines57
Sep 24, 2015 01:58 PM
