Weak brake & high mount light output...help
Old Jul 15, 2016 | 12:54 AM
Drei's Avatar
2005 Acura RL
Is this an easy fix? Something that has to be replaced?
Looking to fix this fast
Thanks!
Old Jul 15, 2016 | 09:36 AM
oo7spy's Avatar
It helps to elaborate your issue outside of a headline title.
Start with the brake switch under the dash.
https://acurazine.com/forums/second-...orking-884224/
https://acurazine.com/forums/second-...msl-ng-870837/
Old Jul 17, 2016 | 02:19 PM
Drei's Avatar
Well I have a 2005 RL with navigation only.
There is a weak output of the brake and 3rd brake light when the brake pedal is pressed. I know for a fact that the LED's are fine since when I've followed the car, they sometimes light up at full brightness, but this only happens 1 out of 8 full braking instances.
007spy, I'm confused about the part numbers,
36750-SMA-013 isn't listed as being compatible with the RL at all
36750-SJA-013 is listed as being compatible
Should I go with 36750-SJA-013?
Thanks!
95oRANGEcRUSH
Jan 7, 2024 07:05 PM
00TL-P3.2
Feb 11, 2019 11:23 AM
usdmJON
ILX Performance Parts & Modifications
15
Sep 8, 2016 12:04 PM
Imager
2G RDX Problems & Fixes
Jun 3, 2016 01:38 PM
