VSA issues in frigid cold?
Old 02-05-2007, 09:27 AM
synth19's Avatar
Twice this weekend I've had my car parked outside for hours with temps well below zero. When I came back to my car, the VSA indicator was on and I was getting the "Check VSA system" in the multi-info display. I turned off the car both times, and then started up again... the warnings then vanished. Anyone else have this issue?
Old 02-05-2007, 11:41 AM
RL06tech's Avatar
Can happen if ice forms on the sensor. Also if you park on a slippery surface that immediately activates the VSA it will also go off. Should not be a problem. Once I slipped into a snow bank covering the entire assembly with snow. It gave the VSA issues for a few minutes.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
hedzup
1G RL (1996-2004)
06-29-2016 08:07 AM
Skirmich
09-15-2015 06:41 PM
Stu2414
4G TL Problems & Fixes
08-30-2015 07:30 PM
Quick Reply: VSA issues in frigid cold?
