vibration at speed that resoves
Old Oct 29, 2022 | 05:36 PM
maggarjt's Avatar
I recently switched to Bridgestone Potenzas in my RL. I had new front shocks as well installed and the shake was horrible at highway speed. I took it to a more competent shop and they found a bolt that needed tightening in the shocks and it went away.
Now it shakes initially for a couple miles and then resolves into normal smooth driving each time my car is driven after sitting for a couple of hours.
I am assuming this is the tire and not a suspension component right? I will try to adjust the pressure of the tires to see if I can change the tendency to shake.
I have done alignment and balancing of the tires already twice.
Any input or has anyone else had any issues like this?
Old Oct 29, 2022 | 07:08 PM
deepa1600's Avatar
That initial shake is most likely flat spots on tires from sitting, when tire warms up shake goes away. Happens with some tires. Remember RL is a heavy car.
Old Oct 29, 2022 | 09:03 PM
maggarjt's Avatar
Thanks. I assumed it had to be that but I've never had that on any other car really, although I always run Michelin pilots or mxm4 and these are the first Bridgestones I have ever owned.
Thanks so much
DatRL
32
Nov 22, 2016 01:57 PM
neil4
5G TLX Problems & Fixes
15
Mar 29, 2016 12:56 PM
0utl
Nov 23, 2015 05:10 PM
b0n3
34
Dec 28, 2010 02:52 PM
tmsz
Mar 28, 2007 09:59 PM
