vibration at speed that resoves
I recently switched to Bridgestone Potenzas in my RL. I had new front shocks as well installed and the shake was horrible at highway speed. I took it to a more competent shop and they found a bolt that needed tightening in the shocks and it went away.
Now it shakes initially for a couple miles and then resolves into normal smooth driving each time my car is driven after sitting for a couple of hours.
I am assuming this is the tire and not a suspension component right? I will try to adjust the pressure of the tires to see if I can change the tendency to shake.
I have done alignment and balancing of the tires already twice.
Any input or has anyone else had any issues like this?
Thanks. I assumed it had to be that but I've never had that on any other car really, although I always run Michelin pilots or mxm4 and these are the first Bridgestones I have ever owned.
Thanks so much
Thanks so much
