Valvoline Maxlife available for Rear Differential fluid!?
Hi! Fellas!
My 09 RL is about 100k miles.
I'm planning to change the drive train fluid.
These are the lists.
1. Transmission(2.66L) -> Valvoline MAXlife dex/merc - 9qt
2. Transfer Case(0.43L) -> AMSOIL 80w90 GL5 - 1qt
3. Rear Differential(3.33L) -> Valvoline Maxlife dex/merc - 4qt
I'm not sure that Valvoline can be used for rear differential.
I know the fact that ATF-Z1 was used for both transmission and rear differential.
However, after ATF DW-1 has been released, DW-1 cannot be used for the rear diff but only used for transmission.
Here is the question. Is it fine to use Valvoline Maxlife dex/merc ATF fluid to Transmission and rear diff?
I saw many people who use Valvoline maxlife to transmission, but as rear differential fluid? hard to see...
Thank you for your reply in advance!
altair47 (02-28-2022)
Hi! Fellas!
OK, so let's see if I have this correct:
Transmission: ATF DW-1 (purchased from Honda dealer) and Valvoline are acceptable
Rear Diff: Acura DPSF and Valvoline are acceptable.
Right?
Now, is Honda DPSF acceptable for Acura rear diff?
Right?
Gimpies-Daddy (07-25-2022)
Yes, I DID answer your question in the link I attached to my previous reply that you obviously didn't read. I answered it specifically and with the full name of the product variety you should and should not buy. Perhaps you'd like to go back and read it. Or, perhaps not.
No need to reply. I got the answer from altir47 up there.....thanks to him/her for that!!
Buffa
15
10-28-2013 02:27 PM
