valve stems ?
Old Nov 15, 2011 | 03:15 PM
pearlrl's Avatar
valve stems ?
are there any Acura logo metal valve stems with plastic inside (threading).. metal ones freeze to the stem
Old Nov 15, 2011 | 04:06 PM
mitchkramez's Avatar
Valve caps, not stems. Found these: http://www.amazon.com/Silver-Chrome-.../dp/B004YK3ODW
not plastic but says it'll never seize on the stem:
* Tire Valve Stem Caps made from high quality ABS plastic with solid brass core that will never seize on your wheel.
* Chrome plated to severe standards and completed with a brilliant embossed 3-D, domed logo of your choice these caps ooze quality and good looks.
* The cone shape allows for a large logo that can be seen.
* Cap will fit on standard tire stem. (please check if you have TPMS on your car)
Sold as a set of 4 Valve Caps in one case.
Old Nov 15, 2011 | 07:32 PM
HEAVY_RL's Avatar
The dealer sells them too.
And if you can live with out the logo most parts stores carry a brass and plastic core cap.
Old Nov 15, 2011 | 09:19 PM
Professor's Avatar
Карты убийцы
Question: If you have, and most Acura's do, TPMS, will these caps fit?
Old Nov 15, 2011 | 09:30 PM
Professor's Avatar
Карты убийцы
Well since they didn't cost much... I bought this set.
http://www.amazon.com/Acura-Logo-Chr...sim_sbs_auto_7
Old Nov 16, 2011 | 10:00 AM
oo7spy's Avatar
It should be a universal size regardless of TPMS. Something to keep in mind, when you take your car to a tire store, take any cap you care about off because the technician will not care about them as much as you do.
Old Nov 16, 2011 | 11:43 AM
Professor, I think the concern over the "metal" and not brass insides was they seize on the stem after a few winters... but maybe that's not a concern where you live...
Old Nov 16, 2011 | 02:05 PM
Professor's Avatar
Карты убийцы
I agree 100%. I took the RL to the dealer, and they didn't even put back on a cap. The bad part is the OEM was a tiny brushed aluminum looking caps. They could not order those, so they stuck me with a set of plastic ones.
Old Nov 16, 2011 | 03:21 PM
oo7spy's Avatar
Same here at Discount tire. I went in with the OEMs and came out with two black plastics, one grey plastic, and a "chrome" aluminum that looks like a hex nut. I was going to let it go until I noticed the chip in my paint on the wheel. I noticed that when I checked the PSI and saw it 7-8 above spec. The paint chip sent me back in to complain, the other two issues were just icing. They could not find my caps, so I left with 5 of the "chrome" ones, correct tire pressures, and a date for refinishing at their expense.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Mike734
Dec 10, 2021 01:25 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
prbori
Sep 27, 2015 01:37 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
