valet key?
valet key?
I'm about to send of my RL on a cross country transporter. I can pack some things in the trunk and don't want to give the driver access to it. So I flip the switch in the glove box and lock it with the key. Now I just give the fob, sans key, to the driver. The problem is that the fob has no hole if the key isn't in there. So now he can't put a split ring on it or hang it somewhere etc. I'm sure this can be overcome but it seems to be an issue if you use valet parking (I never do if I can help it).
What do you give the valet driver and if you only give the fob, does he complain about that?
I give the fob to a valet at least twice a week, and I've never gotten a complaint.
EDIT: Although, truth be told, it sometimes takes a LONG time to get my car -- I think because valets are confused about the keyless system. I always point it out to the valet, but since it's rarely the same guy who fetches the car that takes it from me... it's usually pointless.
![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
Why not just make things easier for the guy on the transporter and remove the key stump so he can just treat it as a regular car when he drives it and not worry about the keyless ignition system tripping him up?
The driver is not supposed to touch my car at all during transport. Drive on and drive off at the destination only. The key is there for emergencies. I will include a note on how to use it. The reason I don't want to give the whole key is because of what I described in the first post. I want the glovebox and trunk to stay locked. You need the metal key to open those.
Actually, I'm about to move the opposite direction, from DC to San Francisco. It is cheaper to ship the car, but I don't trust other people with my car, so I'm going to just drive. How much does it cost to ship the car, anyway?
What concerns me is the "unique" way the RL's starter works. There have been incidents where the RL has not been turned off completely, draining the battery. Maybe I'm just paranoid. . .
About $2250 for 2 cars (RL and A6) from SJ to Ridgefield, CT. If I was single I'd drive but with family and 2 cats it's too much of a hassle. I'm there when they park it on the truck and of course I'll make sure it's all the way off.
use an uncut key
.....The problem is that the fob has no hole if the key isn't in there. So now he can't put a split ring on it or hang it somewhere etc. I'm sure this can be overcome but it seems to be an issue if you use valet parking (I never do if I can help it).
Originally Posted by johnhayd
I learned about the following solution from member of acurazine. Get an uncut emergency key from an acura dealer (about $39 with tax). you can use this to allow the keyfob to be hung up in the usual way. You still have the cut emergency key so that they can't openup your trunk and glove box.
soupi
14
11-15-2015 11:15 AM
