Upper Display
Old Aug 31, 2020 | 09:32 PM
cvgtpc1's Avatar
9th Gear
Upper Display
Have had my 08 RL for 3-4 weeks and still learning this vehicle. Sometimes the upper display is on, other times its not. I would think it should be on continuously or am I unknowingly causing this? Owners manual is no help.
Old Sep 1, 2020 | 05:44 AM
Walfunk's Avatar
Do a search under my name. There is a detailed FYI for this issue.
Old Sep 1, 2020 | 08:04 AM
RL09's Avatar
FkNo!TheyRdstroyinEvrting
That's right do an advanced search plenty of posts.
You have to pop it open (just pull hard up) and disconnect the plug, and then re-solder that circuit.
I dunno how to re-solder so i've been living with it for a few years.
Old Sep 1, 2020 | 08:13 AM
Walfunk's Avatar
You literally just have to touch a soldering iron to the solder for a few seconds. or you can take the unit to a PC repair place (NOT Bestbuys), Will take no more than 15 mins...had mine done about 3 years ago and zero issues...
Old Sep 1, 2020 | 08:18 AM
RL09's Avatar
You're right. I gonna do that today. i'm tired of it a bit
Old Sep 1, 2020 | 08:54 AM
cvgtpc1's Avatar
9th Gear
Thanks! My advanced search skills on this site are hit or miss...
Walfunk, found your post. Great DIY!
Former electronics master solderer so should be simple enough. Flux is your friend.
Nice to see, like RL09 said, you just have to pull up on the display to remove it instead of disassembling the dash. Something easy for once....
Old Sep 1, 2020 | 12:21 PM
RL09's Avatar
A master solderer? Well a shop today quoted me 40-50 to re-solder. It didn't feel right.
Feels like a 20 bucks job takes 5 mins... .
Old Sep 1, 2020 | 01:22 PM
Walfunk's Avatar
My pleasure man. Acurazine has helped me sooo much, it was my way of giving back. You should have it back up and running in about 30 mins...very easy fix.
Walfunk's Avatar
agreed...try somewhere else if possible....
Old Sep 1, 2020 | 02:08 PM
cvgtpc1's Avatar
9th Gear
Probably takes longer to heat up the soldering iron than do the fix.
Old Sep 8, 2020 | 07:56 PM
Gowkaizer's Avatar
6th Gear
Did the same thing, pickup a solder kit for 20bucks at Lowes and didn't myself in 30mins taking it out and putting it back together. Not even an expert just followed Walfunk directions XD!!
Old Sep 8, 2020 | 08:28 PM
Walfunk's Avatar
Yes!!!! So glad I was able to help!! Nice job.
Old Sep 14, 2020 | 11:01 AM
rlx015's Avatar
There is a service you buy on eBay - ship it to the ebay seller, they fix it and ship it back... it came under $20 and few days for a turn-around.. but pretty easy fix ... I just did not want to buy soldering gun and then throw it away since I do not need it ever
nishant11
Jun 1, 2020 04:31 PM
djk7643
Oct 4, 2018 02:59 PM
Rexorg
Nov 18, 2007 11:21 AM
babi_boi_31
3G TL Photograph Gallery
38
Sep 12, 2007 09:17 PM
bradyo
1G RL (1996-2004)
Jun 14, 2007 09:01 AM
