Two Questions from a new RL owner, please help
Old Feb 16, 2006 | 10:30 AM
bearcat2000's Avatar
Hey everyone! Just bought an 05 White Crystal Pearl/Parchment RL and loving it. I do have two questions on it however...
1) Upon starting the vehicle with the HIDs on, just the right one moves to the right and back upon initialization, but it appears as both work when driving. Also when I pull into my driveway I do notice that when I turn the wheel to the right the right headlight moves with the wheel, but not left...is something wrong with my left one or is this just the way it works???
2) When I have the shifter in the "Drive" position, there is a small amount of wiggle room forward and backward. Is this normal as well?
I would greatly appreciate any input on these two matters!!! Thanks! Great to be part of the gang! Bearcat
Old Feb 16, 2006 | 10:58 AM
stingerbtry's Avatar
1--This is normal as the left one doesn't move until the car is going 10 miles an hour or more. This is just a test of the active lighting system when the car starts.
2--I've never tried this but unless the car is popping out of gear, not staying in gear, or making noise/shuddering etc. then you probably don't have a problem. I will check mine at lunch to see if there is any play in the system.
Old Feb 16, 2006 | 11:17 AM
Thanks for the quick reply on the headlights...a good piece of mind to know they are working fine...look forward to hear if you have a little play in the shifter. Thanks again.
Old Feb 16, 2006 | 11:36 AM
vp911's Avatar
Welcome to the forums.
1 and 2 are both normal. I remember my RL did the same for both.
Old Feb 16, 2006 | 11:23 PM
tyrael's Avatar
goodbye RL for now...
normal over here...
Old Feb 17, 2006 | 09:01 AM
Treblig's Avatar
That small amount of wiggle room is present in any location other than park.
Old Feb 19, 2006 | 11:57 AM
RL GRAY's Avatar
Hi
The head light will not move due to avoiding blinding another driver when turning left such as an intersection. that is why you need 10 mph or better.
vaughanml2
Nov 1, 2021 10:16 AM
IIDXholic
Oct 8, 2015 07:53 AM
V-tecAc
Sep 21, 2015 09:25 AM
datadr
Sep 12, 2015 09:12 PM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
