Transmission mounts - need some help
Old Mar 28, 2019 | 07:30 PM
H8PVMT's Avatar
I recently replaced my motor mounts, once that was done there was a vibration coming from the engine that wasn't there before, I had assumed that because the mounts were fixed the transmission mounts were now in need of replacement and taking all the vibration thus causing more vibration than normal.
I bought a transmission mount, front upper for 24.99 with hopes that the more expensive mount was fine.
I got the mount, tore the car apart and for the life of me I can't find the mount. I did however find the lower more expensive mount and it's shot so there is that.
for our car, are there two mounts? I also found a couple other mounts that I have no idea what they are for but seem to be in need of replacement.
Any help would be appreciated.
Old Mar 28, 2019 | 07:35 PM
H8PVMT's Avatar
Some pics to help
This is right against the sway bar back side under the transmission
I bought this mount, should be front upper but there isn’t anything like it around
This is lower left under headlights and battery box, i have no idea what it is or what it does.
Expensive mount broken.
Old Mar 30, 2019 | 11:49 PM
H8PVMT's Avatar
I’ve searched the car over and over, the mount that I purchased does not go on my car, I’m 100% certain. However, I did find the transmission mount that’s bad. I found a replacement at parts geek for 309 and a 15.00 coupon with free shipping and no tax made it 294.00
here is the old busted mount, makes sense that I was feeling a large vibration.
Old Apr 1, 2019 | 12:44 PM
Ali Islam's Avatar
8th Gear
Those always break
Those are always busted.
Old Apr 2, 2019 | 06:50 PM
deepa1600's Avatar
Mine is also busted, unfortunately it's an expensive endeavor to replace engine mounts on our cars. I also ordered a transmission mount from Amayama.com I paid about 260$ Canadian (195 USD) including shipping, mount, bunch of bolts. Car has about 140k miles.
Old Apr 5, 2019 | 08:32 AM
projektvertx's Avatar
It's a Honda mount thing. I'm convinced Honda can't design mounts if their lives depended on it.
Old Apr 8, 2019 | 05:11 PM
H8PVMT's Avatar
Against my better judgement I'm taking the car to the dealership to have her looked at and help to determine what is wrong. After replacing all the mounts in the car (3 motor and 1 transmission) I'm still getting a vibration at a stop while in gear. I can't figure it out. I made sure the vacuum lines were hooked up, made sure the mounts were bolted on properly... just no idea. So for 90.00 hopefully they can tell me what is wrong and God willing it's cheap.
Old Apr 11, 2019 | 12:40 PM
RG08RL's Avatar
Please let us know the outcome. I'm also experiencing severe vibration at idle after replacing the rear motor mount. The vibrations get really bad between when the speedometer hit 15mph all the way to 30mph, once you pass the 30mph range, the vibrations subside and the car feels good as new. I first replaced the front and side engine mounts last month and I saw a big improvement in the car and didn't experience any vibrations. It was until last week that i finally had the time to replaced the rear engine mount and that's when the vibration started. It was mention on some post that the vibrations might eventually stop after driving the car for a while, since it might be that the engine mounts are new and stiff, but I don't know if that is true or not. On one hand the vibration in idle is kind of annoying for this type of car, but on the other hand, it almost give you that feeling of a muscle car with a big Hemi engine under the hood.
Old Apr 12, 2019 | 06:33 PM
deepa1600's Avatar
Today i changed the front mount. It was PITA, i did it without removing fans as my rfc unit's screws were rusted.
Old Apr 16, 2019 | 07:47 PM
H8PVMT's Avatar
update: Took the car to the dealer and they found that the passenger mount was broken, yes the new one I installed. I got a hold of mount_expert on eBay and they promptly refunded my money with just a picture of the broken mount (great service) I did opt to buy the OEM mount. I installed it myself and still am having the vibrations at a stop light or stop sign or anywhere I'm stopped with the car in gear.
I'm also feeling the vibrations around 60 mph. I decided to do a little test - I put the car in manual and around 60 I stayed in 4th and got zero vibration, put it in 5th and the vibrations came back. Not sure what that means but it's something. I'm going to take the back to the dealer next week to have it looked at again, I'm at a total loss. They double checked all my work and all of it was perfect, now I wait, which I'm not good at doing.
I'll update again next week.
Old Apr 21, 2019 | 01:21 PM
deepa1600's Avatar
Changed transmission mount, it was shot too.
Old Apr 23, 2019 | 04:21 PM
Acura05rl's Avatar
What part # is it for the transmission mount?
Old Apr 23, 2019 | 04:52 PM
H8PVMT's Avatar
from parts geek, W0133-1774508
Old Apr 23, 2019 | 05:21 PM
Acura05rl's Avatar
Thanks. I found oem part # 50850-SJA-A01.
Can be had from dealer a bit cheaper. Around $250 with shipping.
Old Apr 23, 2019 | 09:38 PM
deepa1600's Avatar
50850-SJA-A01 use Acurazine as coupon cide to get 5% off.
Old May 2, 2019 | 07:06 PM
H8PVMT's Avatar
Alright... I'm losing my mind.
Recap:
I replaced all my motor mounts and transmission mount (we only have one - that the dealer is saying and that I can find). I was still getting vibrations in gear at a stop and low RPM's.
The passenger mount broke, I replaced it with OEM - still vibrations
Dealer said the front mount was moving too much, I replaced the front and rear mount with XLR8 mounts. Still getting vibrations. When I say vibrations it's annoying, you can feel it through the whole car, it's not a cool horsepower vibration either.
I haven't checked the transmission mount yet (the new one to see if it's damaged somehow).
With all that, what am I missing - there has to be a reason that I'm getting these vibrations, an explainable reason and a fixable reason.
Any thoughts or input would be wonderful.
Old May 2, 2019 | 07:07 PM
H8PVMT's Avatar
What part is this? I haven't replaced anything like this yet.
Old May 2, 2019 | 07:21 PM
deepa1600's Avatar
It's the transmission mount, the same one you replaced. I know it's confusing as the pictures are different.
Old May 2, 2019 | 07:24 PM
H8PVMT's Avatar
Ahh okay, thanks I was hoping I had missed something and was going to finally fix the damn vibrations.
Old Jun 14, 2019 | 03:25 PM
sccrxer's Avatar
I'm experiencing those same low RPM vibrations as you after I swapped my engine and replaced all except the transmission mount. I hoped you figured out what it was! Still no luck?
Old Jun 14, 2019 | 08:44 PM
H8PVMT's Avatar
Well, I ordered the XLER8 front and rear mount, still a lot of vibration. I bit the bullet and bought OEM front and rear mounts, now I'll have all OEM mounts. They should be in my possession on Monday the 17th and I'll install them. Hopefully this fixes it, other wise I'm going to go crazy.
Old Jun 15, 2019 | 08:39 AM
sccrxer's Avatar
You would get extra vibration with the XLR8 mounts since they use a stiffer material. Mine are all OEM and I've got this annoying vibration. My only thought at this point is that maybe the bolt that connects the motor to the mount on each point is too tight and not allowing the slightest movement of the motor, but that seems really dumb to me. I also installed RV6 high flow cats, but you didn't so I'm lead to believe it is a mount issue and not an exhaust note issue...
Old Jun 15, 2019 | 11:49 PM
HDNBenjamin's Avatar
I just bought this with the 5% off. Looks like an easy replacement accoeding to Youtube..I wish someone would make a DIY for the rear engine mount. I have the part but don't not confident I can do it because of the limited space.
Old Jun 16, 2019 | 11:22 AM
sccrxer's Avatar
Remove the strut brace to get better access, remove the top bracket, use either wobble extensions or wobble sockets. Wobble sockets are the better option. You need 1-2' of extension and a breaker bar to get the 4 bolts that hold the to the subframe. The main bolt is very tedious to remove and replace due to an absolute lack of space behind the mount. Just use a 14mm wrench and be prepared to lay on the motor for a few minutes for that one. It's not terrible to replace but it's very tedious. Don't forget to support the motor slightly to get the weight off the mount.
Old Jun 16, 2019 | 01:35 PM
Thank you! This definitely helps!
Old Jun 17, 2019 | 09:47 PM
H8PVMT's Avatar
I replaced the XLR8 mounts with OEM.... 100% better. Zero vibration.
Anyone want to buy a slightly used front and rear motor mount?
Old Jun 18, 2019 | 05:12 AM
sccrxer's Avatar
Hmmmm... My rear mount came from O'Reilly's. Supposed to be an OEM mount. I can't imagine that is causing my vibration, but damn. Now I wonder...
Old Jun 18, 2019 | 11:58 AM
H8PVMT's Avatar
After what I've been through I'd bet that was the problem. This is almost the only time I'd highly recommend to buy OEM. I should have from the get go. Now I learned.
Old Jun 18, 2019 | 12:15 PM
Yup.. OEM mounts are the only surefire way of getting zero vibrations. If you do decide to go aftermarket for the others, do so; but for the rear, always OEM if you value comfort.
Old Jun 18, 2019 | 01:26 PM
sccrxer's Avatar
Of course the rear one is the only one that I bought from a third party... Others are all genuine Honda.
Old Jun 18, 2019 | 01:45 PM
Yeah... whoops
The reasoning behind it is because the rear is closest to the firewall which ultimately transfers the vibrations into the cabin (where you're sitting)
Not too late to just replace the last remaining aftermarket to OEM!
Old Jul 6, 2019 | 07:22 PM
Just replaced the transmission mount on the RL. Super easy to do. 5 bolts total. 2 at the bottom and three against the driver wheel well. I also attempted to replace my rear engine amount but couldnt get the bolts on the strut bar against the firewall out..My neighbor ended up helping. He took the rear engine mount without the strut bar..it was a team effort but i didnt think he would be able to do it. It turned out that my rear engine mount was in good condition..only the transmission mount was broken. car drives great.
rear engine mount still in good condition. Had I known I'd have left it there and only replace the transmission mount. Job would take 30 min lol.
Busted transmission mount
Old Jul 7, 2019 | 12:33 AM
Can anyone who's done the rear engine mount telk me how you took the bolts of the strut tower against the firewall? I tried 10, 11, 12, 13, 14 and none was the right size. My neighbor got the mount off without taking the strut bar off but I am curious how to do it. thanks.
Old Jul 7, 2019 | 06:45 AM
sccrxer's Avatar
You have to remove the cowl to gain access to the hidden bolts that hold the center bars of the brace. I think they're 13mm in there but don't quote me on that. It sounds like you were trying to get at it from the bottom, but the bolts are inside the area hidden by the cowl. Here is the under side and as you can see, the "nut" is welded in place. Sorry, I don't have a picture of the inside to show the top of the bolts from when I did this job.
Old Jul 7, 2019 | 11:39 AM
Thank you!! Yes, I tried to get it from the bottom. Thanks again!
Old Jul 7, 2019 | 10:00 PM
H8PVMT's Avatar
To be fair, the XLR8 mounts have a nut at the bottom of the mount to hold it together, after I replaced mine with OEM I found that I don’t tighten the XLR8 mounts this mostly causing my vibration issues. Had I known.... I would have tightened that nut and been just fine. Again, lesson learned.
Old Jul 29, 2021 | 12:00 AM
Imperial's Avatar
Hi, this is a couple of years old thread, but a good one. The other day, I parked my car next to an enclosed area/wall and shifted transmission from P to R, to D and vice versa. So from P to R, there is some kind of noise, like a clunk or a click. From D to R or R to D is a bit louder. Also when I shut off the car, the is an accompanying metallic click. Oh and I recently was driving slowly, maybe up to 20 MPH and downshifted my car manually from 2nd to 1st gear and felt some thump. How can I see/check transmission mount for excessive movement and possibly take a video?
Could it be transmission mount issue?
Car has 116k miles on it.
Old Aug 3, 2021 | 01:56 PM
accord_3000's Avatar
8th Gear
All,
I have replaced all the mounts on my 06 RL. Including the ridiculously expensive transmission mount.
Originally for the 3 engine mounts I went cheap. This was a bad idea, the car vibrated like mad. I went OEM on all 4 mounts. She's smooth as silk now. This can be done at home, it isn't easy, but if I can do it, you can do it.
03_BigJ_TypeS
21
Aug 1, 2014 12:29 AM
NighthawkBlue
Oct 24, 2012 02:39 AM
luxerymobile
Mar 29, 2011 12:48 PM
HQTL6SPD
Aug 8, 2010 06:52 PM
